08-25-2003, 10:24 PM | #1 |
Bucket seat question
May be buying a 72 which was originally a bench seat truck. PO installed a set of buckets from he believes a 71 truck or blazer. They appear to be sitting lower than a bench would.
Should there be certain mounting brackets installed with the buckets for them to sit "normal" height? Any info is appreciated. Thanks! |
08-26-2003, 09:29 AM | #2 |
ttt
08-26-2003, 12:16 PM | #3 |
If they are Blazer seats with Blazer brackets, they will sit at the same height as the bench seats. I would asssume that the truck buckets would sit as high, also.
I am not sure what you have. Do you have any pics? Jim |
08-26-2003, 12:22 PM | #4 |
YEP -- JIMS RIGHT ON THE MONEY. I'VE REPLACED SEVERAL BENCH SEATS WITH BUCKETS. & IF YOU USE THE STOCK BUCKET SEAT SLIDES & RISERS OUT OF EITHER A PICKUP OR BLAZER, THEY ARE THE RIGHT HEIGHT. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
08-26-2003, 09:19 PM | #5 |
Thanks very much for the info. Hopefully I'll get the truck over the weekend and take a closer look.
08-26-2003, 11:14 PM | #6 |
Did 69 or 70 Blazers come with different looking seats then 71 and 72's? I saw one at a junkyard with metal backs on the seats but I thought all Blazer buckets looked the same.
08-27-2003, 12:37 AM | #7 |
THE QUICKER FIXERUPER
gee emm I belive the seats with the squareish metal backs were called utility buckets.
08-27-2003, 05:22 AM | #8 |
Back in the sticks
uh oh! Whats the difference between regular buckets and "utility" buckets. I thought they all had metal backs to them. Thanks, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
08-27-2003, 08:08 AM | #9 |
Utility buckets are bigger - more square then the sport buckets. Utility buckets did have metal backs and came in the Blazer/BurbsS--but not the light trucks. Sport buckets had plastic backs in the blazers/burbs but no backs in the trucks.
When I put sport buckets into my truck, I used stock, correct truck mounts but was not happy with the "feel" so I put some 2x4 wood blocks under the mounts which raised the seats about 1&3/4 inch. Now the seat backs are slightly higher then the lower section of the rear window metal which allows for the seats to sit back just a bit more. This way I get a little more leg room. |
08-27-2003, 08:19 AM | #10 |
Back in the sticks
Dang! I guess that means I will be looking for a set of the sport buckets. The new seat covers I have probably won't fit either. They are houndstooth model. Man. Anybody want to trade for a set of utility buckets?
08-27-2003, 12:28 PM | #11 |
One more question......the truck I will be getting is a 72 super cheyenne. If I want to keep it stock looking, should the seats be recovered in houndstooth, or did they also use the plain design on the buckets in a 72 super as well (seats not original to the truck, but would like to keep as original in appearance as I can).
Thanks again guys. |
08-27-2003, 12:35 PM | #12 |
CCRider
Buckets only came from the factory with the scroll vinyl covers...the hounds tooth bucket covers are something the parts suppliers started making
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
08-27-2003, 06:59 PM | #13 |
What about the plaid seat covers and the style in my Jimmy, just plain perforated black, they don't have any scroll.
08-27-2003, 10:58 PM | #14 |
There were four available highland trim seat patterns for buckets in Blazers and Suburbans in 72... 71 I think so also..
Metal back auxilary bucket seat were available in all year Blazers.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
08-27-2003, 11:03 PM | #15 |
Also 69-70 truck sub/ blazer / buckets had one scroll and 71-72 truck/ blazer sub/ buckets had 2 scrolls. If they had the sport bucket option... A50.
08-27-2003, 11:08 PM | #16 |
Back in the sticks
Anybody know if the seat covers I have will fit the utility buckets? They are houndstooth style. How much bigger are the utility seats anyway?
08-27-2003, 11:22 PM | #17 |
The utility buckets are quite a bit bigger, maybe 6 inches wider then the sport buckets.
08-27-2003, 11:25 PM | #18 |
truck type buckets same as blazer except for mounting of passenger side... so No the two type seat covers wont interchange.
08-27-2003, 11:25 PM | #19 |
Metal back Blazer seats.
08-27-2003, 11:33 PM | #20 |
Back in the sticks
Anyone know of a set of sport buckets for sale or trade?
08-28-2003, 10:02 AM | #21 |
Wow great info guys thanks, and the pics are really appreciated.
BTW I noticed someone on the board referencing floorpans from a truck with buckets. Is the only difference in the floor pan the bolt holes for the brackets, or were there other changes between a bench vs bucket truck floorpan? |
08-28-2003, 10:09 AM | #22 |
Resident Curmudgeon
The floorpan is the same with all seat configurations. The bucket equipped trucks had a different bolt hole location and reenforcement brackets welded to underside of cab.
It's an easy swap to put in OE 69-72 buckets in place of your bench...and it's a CPNE approved upgrade!
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
08-28-2003, 07:05 PM | #23 |
Actually the utilility bucket Blazer I have has the passenger side latching thing closer to the edge as opposed to being in the center for the sport buckets. There is a support bracket that I need for my sport bucket Jimmy and the Utility bucket Blazer doesnt have it under the floor.
08-28-2003, 11:02 PM | #24 |
Ok, unfortunately they are the blazer buckets, almost identical to Rod's pic above. Can anyone give me an idea of what the pair including mounting brackets and a center console are worth (driver's seat torn)? I may decide to go back to a bench.
Thanks again to everyone. |
08-29-2003, 07:28 AM | #25 |
Does anyone sell replacement foam for the buckets? I'm getting ready to recover mine and I really could use new foam on the driver's side.
