Old 02-24-2015, 11:58 PM   #1
wyattglock
wyattglock's Avatar
2002 1500hd headlight switch
Does anyone know if the headlight switch from a Suburban will work in a 2002 1500hd ls? I do not have the ability to shut off the headlights in park and would like to have that for when I am going hunting. Thanks in advance
wyattglock is offline   Reply With Quote
Old 02-25-2015, 10:10 AM   #2
95 S_Trucker
95 S_Trucker's Avatar
Re: 2002 1500hd headlight switch
Push the dome override button 4 times within 4 seconds. It will turn off you headlights.
The switch from a suburban will be the same as your pick up.
95 S_Trucker is offline   Reply With Quote
Old 02-25-2015, 10:14 AM   #3
wyattglock
wyattglock's Avatar
Thanks for the tip! I have a friend with a 2002 Suburban and he has a four position switch. Basically his has Auto, off, running lights, and headlights. Mine on the other hand has a three position switch, but is basically useless with the stupid daytime running lights.
Old 02-25-2015, 12:08 PM   #4
95 S_Trucker
The daytime running lamps are on all the time on the suburban too, unless you hit the button 4 times.
Old 02-26-2015, 04:44 AM   #5
wyattglock
wyattglock's Avatar
Good to know. Thanks for the tips. I wont be wasting my time on changing that out.
Old 02-26-2015, 09:45 PM   #6
seattle gmc
seattle gmc's Avatar
My truck is newer so it might be different, but i can trun off the day time running lights by simply turning the knob all the way to left once.
1970 GMC K2500 aka MaTeR
2007 Chevy Silverado 1500HD Classic
seattle gmc is offline   Reply With Quote
Old 02-26-2015, 11:17 PM   #7
wyattglock
wyattglock's Avatar
Mine is all the way left all the time. Pushing the dome light button 4 times in 4 seconds works. Thanks for the info!
