Old 02-25-2015, 04:50 PM   #1
rudyyloverboiii
used to stay on.
Burned my under dash wires. Bought a "stock" harness installed it. New starter harness n wih the key it wont start. When i hot wire it cranks over n wont stay on. New oem voltagr regulator n horn relay. Starter rebuilt n so is the generator/ alternator. New battery. Stumped, need help please
rudyyloverboiii is offline   Reply With Quote
Old 02-25-2015, 05:08 PM   #2
jchav62
1962 C-10
jchav62's Avatar
Re: used to stay on.
Make sure the hot wire to the coil stays hot with the key in the 'on' position.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 02-25-2015, 05:29 PM   #3
Tazimafied
Bad switch?
Tazimafied is offline   Reply With Quote
Old 02-25-2015, 07:28 PM   #4
par4tom
Tracing this down, it sounds like you have 12v constant to the starter else it wouldn't turn over. Check that one off the list.
If you hot wire it, the starter cranks so the wire to the solenoid is correct. It just doesn't have voltage when you turn the key to the start position.
Double check that you have constant 12v (always hot) to the key and not a 12v switched to the key (has power when the key is on). If memory serves me correctly, when you turn the key to the start position, it disconnects the other 12v switched items and that might explain why the solenoid isn't kicking over.
And I agree with one of the other posts...make sure you have a good steady 12v switched power to the coil when the key is turning the motor over...I'd use a volt meter and check the voltage at the coil both when you turn the key to the start position and you are trying to start to motor as well as 12 volts when the key is in the "run" position...
If you do have voltage at the key in the off position and in the start position but no voltage to the solenoid, you've got a bad key ignition...
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=705185
How to Get Audiophile Sound in 60-66 Trucks
http://67-72chevytrucks.com/vboard/s...=1#post7236896
Building Your Own Speaker Kick Pods
http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495
par4tom is offline   Reply With Quote
Old 02-26-2015, 10:59 AM   #5
rudyyloverboiii
Thanks guys for the input. It was a bad ignition switch. Cousin n i put a jumper on starter n hooked up a toggle switch. Turned it on like that then tried to turn it off with the key n it turns it off but it wont turn it on. I decided to leave the toggle switch in. Kindof like a kill switch or push to start.
Old 02-26-2015, 11:21 AM   #6
joedoh
joedoh's Avatar
make sure the toggle switch is rated for the load!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 02-26-2015, 07:33 PM   #7
rudyyloverboiii
What do you mean joe
Old 02-26-2015, 11:16 PM   #8
joedoh
joedoh's Avatar
using a toggle switch for starting, or for ignition, you need to make sure the toggle switch is rated for the load or you can fuse the contacts and start a fire. the starter should be a low amperage circuit to close the solenoid, but still can draw 10-15a, the ignition draw will be whatever is hooked to the ignition circuit but can be that high as well. the toggle switch will have its rated current printed on it. heat is the first clue you are drawing too much current, so feel it while in use.
Old 02-27-2015, 04:39 PM   #9
rudyyloverboiii
so in other words kind of keep track of it that it doesnt get hot and cause a fire ha? I havent noticed it getting hot. guess i will just have to wait and see. thankd joe
