02-25-2015, 07:49 PM | #1 |
Best seam sealer
My cab is hand stripped to bare metal and I am starting on bodywork. I don't have any rust issues. I stripped all of the factory seam sealer out of the rain gutter, stripped where the rockers spot weld on to the cab pillars, etc.... I can't remember the brand of sealer I used the last time I painted my '38 Dodge and I can't find it online.
I will etch prime ahead of sealing. I plan to paint with Summit Hot Rod Flat red Acrylic Urethane paint. What is the best seam sealer to use here and also in the floor, etc...? I am painting myself. This truck will be a regular driver sitting outside a lot in the AZ sun year 'round. Thanks, Tom
Please Watch for Motorcycles Last edited by T.W.Dustin; 02-25-2015 at 07:57 PM. |
02-25-2015, 08:09 PM | #2 |
Re: Best seam sealer
I have been using this for about 10 years or so and I have been very happy with it. It is sand-able (although it takes work) and has held up on several trucks well. Since I didn't need to sand it much because of being covered, using it on interior seams was great. I am able to brush it on too in many locations.
http://www.eastwood.com/ew-brush-on-...ler-quart.html The hardest (most work) issue for me was when I did the drip rails on my 70 C10. The sanding/blending into the body to make it look smooth was a good bit of work (since it is not a self-leveling sealer) but the end results were very good looking.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 02-25-2015 at 08:22 PM. |
02-25-2015, 09:40 PM | #3 |
I been lookin at this same issue. I found a product but haven't used it yet. Evercoat Maxim self leveling seam sealer part number 100824
02-26-2015, 11:01 AM | #4 |
Thanks guys I appreciate the feedback. It may seem like a trivial step but it is "under the paint" and therefore very critical to what the end result will look like down the road :-)
Please Watch for Motorcycles |
02-26-2015, 11:24 AM | #5 |
used this when I re-did my s10. Havent sealed the gutters in my 65 yet.
http://www.3m.com/product/informatio...ek-Sealer.html
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=518877 |
02-26-2015, 06:15 PM | #6 |
US Army Veteran
A few guys here recommended this one:
Amazon.com: BRUSH SEAM SEALER, QT: Automotive Picked up a quart, but have not used it yet. Mostly gathering up all materials for a spring paint, when it warms up.
1972 C10 Highlander - The making of a daily driver |
02-27-2015, 09:34 PM | #7 |
Thanks for the suggestions! Looks like I got moved to "paint and body". Seems like a slower area of the forum over here :-(
03-24-2015, 12:04 AM | #8 |
60-66 Nut
I am having trouble finding the Evercoat Maxim 100824....where are you guys finding it? I am hoping to stay with a single cartridge type so I can use a regular caulking gun. Is the Eastwood 2K self leveling seam sealer any good?
03-24-2015, 12:15 AM | #9 |
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
03-24-2015, 01:30 AM | #10 | |
60-66 Nut
Thanks, but I have read that thread. I just have not found the gun for $25.00 let alone the gun and a cartridge for $25.00. I'll keep looking.
03-24-2015, 12:11 PM | #11 |
Everything I see listed here is 1K the "Brushable" and all are 1K. 1K simply "dries" like old lacquer paint and primers. I just seam sealed the gutter on my daily driver 1959 Rambler yesterday, and it got 2K seam sealer. 2K, yes is more expensive, yes it requires a more expensive gun, but darn it, it's a thousand times more durable than 1k. 2K is like epoxy or urethane primers or paints. It doesn't "dry" it "cures" with the molecules linking up to form a new material. This material is solvent resistant, water resistant, and adheres much better. It's what the collision industry uses every day on 2014 cars when repairing them back to manufacturers specifications.
At work, we have about 10 air powered guns for the sealers we use. Yes they are very expensive, at home I have a manual one. I have used it for metal structural panel adhesive, plastic structural adhesive, seam sealers, expandable foam. The tubes stay good for years if you leave them with the mixing tube on it after you use it. The mixed stuff in it hardens and seals off the tube from the air so it won't cure or dry out. You unscrew the mixing tube and put a new one one, and you are ready to go. Really think about upping to this 2K it's a big step up. Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
03-24-2015, 01:24 PM | #12 | |
Willie Swamp Angel Truckers '72 C10 Highlander People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. |
03-24-2015, 01:38 PM | #13 |
I honestly don't need to make a recommendation more than the name brands, that's all you need. 3M Fusor, SEM, we use a commercial brand "Winzer" at the shop and I of course get it for home.
Evercoat has 2K products that don't need a special gun. http://www.evercoat.com/productcategory.aspx?cat=41 Look over their stuff and be sure the one you get is 2K they may have both. And I have to say, Evercoat is one of those companies that if they started selling TV's I would buy one. I have used their stuff for decades, spoke with the tech department many times they are always helpful. Their products are spot on, there is frankly no reason to go anywhere else as far as I am concerned. Brian
03-25-2015, 12:59 PM | #14 |
3m ultrapro.
