![]() Join Date: Dec 2014
12 bolt question?
Hello,
Would a posi unit from a later truck (73-87) 12 bolt fit in an earlier 60's 12 bolt? Are the axle spline counts the same? Thanks for your input! |
Re: 12 bolt question?
I think the're all the same but the axle splines were 17 spline up to 64 then fine spline after that
60-66 Nut
![]() ![]() Join Date: Mar 2007
The truck 12 bolt was used from '63-'82. The '63 and '64 12 bolts had 17 spline axles. The '65-'82's had 30 spline axles. The truck 12 bolt carriers all interchange in the truck 12 bolt housings. You just have to use the correct axles for the spline count in the spider gears in the carrier.
Thanks for the info guys! I though the spline count changed at some point. I've got a line on a 60's 12 bolt to fit my truck, but wanted the interchange info before I made a deal, thanks again!
I don't know if it fits in your equation at all but in 1970 they went 1 1/2" wider and in 1971 they went to 5 stud axles.
#6 | |
Thanks again guys for sharing your knowledge! Jeremy |
60-66 Nut
It was mid year of the 1970 model year that the width increased from 62" to 63.5".
Any info about pinion splines ? I just bought a new ring and pinion and it looks like I will need a different Yoke as its much finer. Hope it works other than that !
Interesting, I would have guessed they were all the same, hopefully someone will chime in, I just picked up a 12 bolt I'm gonna build so I'd like to know if there are differences, thanks for posting
60-66 Nut
The '63 & '64 12 bolt pinions and corresponding yokes had a coarse spline just as the axles did.
So I can just replace the yoke only with a 65-80ish model and all should be fine ?
#13 |
60-66 Nut
Yes. You should also replace the seal.
