making a lifted truck ride better
I have an 86 k20 lifted with a shackle flip in the rear along with 4 inch lift springs In the front. Was wondering if there was any way to make it ride better? Differnt shocks or springs?
1986 chevy k20 4inch lift 35 inch duratracs ![]() |
Re: making a lifted truck ride better
Buy a 2wd truck and put airbags in.
3/4 ton lifted put lighter lift springs i had them setting right down over loads fliped those but any of that can affect ride hight also. Big nitrogen shocks dont help. Try trowing some wieght in back see if that helps.
83 c10 long Box Daily Driver 90 Jimmy parked 98 Road King/ 06 Road Glide In memorium 63 impala SS/ 65 Chevy Panel 65 GMC Short Box/ 68 Camero |
The last truck i rode in with bag rode worst then my lifted k20 6" all spring and 3" body on 39 boggers I let my tire down about 5 to 8 psi help a lot but like I said it was on 39
What Hump?
Air ride seats
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
almost scrap
![]() Join Date: Sep 2009
tires will change ride quality too. I went from Michelins to BFG A/T's and noticed a huge difference.
What is your complaint with the ride? It is my belief that the springs take the harshness out of the bumps, and the shocks limit how much you "spring/bounce" AFTER the bump. So if the ride is too harsh, that's springs. If its too bouncy after the bump, that's shocks. Tires help a lot too. A big sidewall and lower air pressure helps. A 24" wheel with little sidewall is going to make for a harsh ride.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. Last edited by 71swb4x4; 02-26-2015 at 02:52 PM. Reason: spelling |
Ya forgot about that air pressure in tires make ahuge differance 85 vs 55 if your not hauling much
It's just overall ride quality. I'm running 35 inch duratracs with a 16 inch wheel at about 25 psi
Depends what brand leaf springs and shocks you have on it now.
