Old 02-26-2015, 11:48 AM   #1
Possmguts
Possmguts's Avatar
Control arm shaft rubber?
Im looking all over for just the rubber boots for the upper and lower control arm shafts.... anyone point me in the right direction? There is no play in the shafts I already have, just need to boots is all.
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 02-26-2015, 12:34 PM   #2
sduckworth13
sduckworth13's Avatar
Re: Control arm shaft rubber?
You could give Moog or Rockauto a call and see if they'll sell them individually. Good luck.
Scott
sduckworth13 is offline   Reply With Quote
Old 02-26-2015, 12:36 PM   #3
67 cst swb
67 cst swb's Avatar
If you are talking about the stock 67-72 control arm shafts.
You can give Cory at Tuckers a call. He has some OE GM one's if I remember correctly.
http://www.tuckersparts.com/
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 02-26-2015, 07:27 PM   #4
miniman
I got mine from O'Rielly's, they had them on the shelf.
miniman is offline   Reply With Quote
Old 02-26-2015, 07:53 PM   #5
snipescastle2
snipescastle2's Avatar
Classic parts has them, they weren't too expensive.
Ben Smith
snipescastle2 is offline   Reply With Quote
Old 02-27-2015, 02:07 PM   #6
67 cst swb
67 cst swb's Avatar
Moog does not show a part number, neither does Raybestos (bought out by Moog) and no comment on Rock Auto.
My Trucks:
Old 02-27-2015, 09:49 PM   #7
Possmguts
Possmguts's Avatar
After closer inspection once I had all the shafts off there was some pitting in the thread areas so I just order the full upper and lower shaft kits. But thanks for the input guys.
