Old 02-26-2015, 03:45 PM   #1
rs74
rs74's Avatar
Live and learn. Thought I scored today.
A couple of months ago I sold a 6.2 diesel engine to a guy. He had mentioned that his friend was at an estate auction and came across a new GMC grill still in the box. He called the guy who bought bought my engine knowing he had a GMC and was told to buy it. Once it got back home he realized it was for a newer style as he had a 79 model.
He told me what he would take for it. So today I made the trip and picked it up. It wasn't until I got back home that I ran the number that was on the box. 15553637 is the number which come back to a 91 van. A van grill???? SMH.
It is a nice new grill though. Lol. I guess I should have run the numbers while I was there picking it up. Oh well.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 02-26-2015, 04:18 PM   #2
J Knight
J Knight's Avatar
Re: Live and learn. Thought I scored today.
I could be wrong but I remember someone posted that van grilles are the same as truck grilles.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 02-26-2015, 04:23 PM   #3
rs74
rs74's Avatar
Lol. I have it tore apart now to see. It looks like it might go right in. One difference I see so far is that the GMC letters are made into this grill where the others bolt on. Will post pics if it goes in.
Roy
1987 R10 shortie
Old 02-26-2015, 04:53 PM   #4
kevinr1970
Before you give up on it, verify if it is the same as the grill on yours.
It might have been that at the time it was purchased, it was only compatible with a current vehicle, and in '91 that would have been a van?
I know the van grills in some cases are very close, maybe even cross over?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 02-26-2015, 06:29 PM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
looks squared off to much
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 02-26-2015, 07:11 PM   #6
Pano
Looks like the grill in my 87 V2500.
Pano is offline   Reply With Quote
Old 02-26-2015, 09:15 PM   #7
rs74
rs74's Avatar
I ended up taking the grill out of my 86 K30 and put it in the 84 diesel short bed. I put this van grill in the K30. The new grill is for a 91 G1500 van. The grill is almost identical to the factory 86 grill I took out of my K30.
The only difference that I could see were that the GMC letters were molded into the grill rather than a bolt on. Also three of the mounting fingers on top are a bit longer. Where the mounting clips slide on the grill actually set back towards the radiator enough that you can't use them. There are five screws that bolt this down on the top side. Of those five I could only use two. The first screw on the left, middle and last screw on the right I could not make work using the clips. Tomorrow I think I am going to drill a couple of new holes in the grill so I can bolt it down.
Oh I should also say that where the screws go through the mounting panel there are two sets of holes. One is the factory location. There are another set directly behind those holes that set back about 1/2". I had to use those new holes to get the two screws that I have in there now. I will get a pic of that here in a few. Here are a couple of pics of the truck and also the new grill in the K30. You will also see the GMC letters are molded rather than bolt in too.
Roy
1987 R10 shortie
Old 02-26-2015, 09:16 PM   #8
rs74
rs74's Avatar
More
Roy
1987 R10 shortie
Old 02-26-2015, 09:19 PM   #9
rs74
rs74's Avatar
I didn't like the factory 84 grill when I first got the truck but it grew on my. Just wish it wasn't all faded and chaulky. It did have some broken tabs and fins on it though. I kind of think it gave the truck a little more of a "race" look. I do like the 86 grill on it too. Gave it a little updated look I think. Just doing little things to it as I can.
Roy
1987 R10 shortie
Old 02-26-2015, 09:35 PM   #10
rs74
rs74's Avatar
pics
Roy
1987 R10 shortie
Old 02-26-2015, 09:38 PM   #11
rs74
rs74's Avatar
Picture of the 86 grill in the 84.
New 91 grill holes in the second pic. Other than those three holes it fit really well.
Roy
1987 R10 shortie
Old 02-26-2015, 09:40 PM   #12
rs74
rs74's Avatar
Not bad for $40.
Roy
1987 R10 shortie
Old 02-26-2015, 09:56 PM   #13
1774btcrew
1774btcrew's Avatar
The van grilles are technically the same. You can drill the holes to mount it and then square them off for your plastic clips. It really isn't too bad to do. As far as the letters go, you can also drill the holes to mount them. I hope this helps. It looks to me like you scored.
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 02-26-2015, 10:50 PM   #14
motornut
78K & 79C Jimmys
motornut's Avatar
oops that was my 89,yup my 87 was like that too,for 40$ yup thats a score
John
