Old 02-26-2015, 11:07 PM   #1
cst 72 blazer
cst 72 blazer's Avatar
Angle plug headers that fit a 4wd?sbc
hey guys sorry in advance for a subject that has been beat to death. ive been doing some digging with not much success. anybody here have angle plug sbc heads on a 4x4 blazer with long tube headers? brand? part# . seems like most threads are 2wd and im concerned with front drive shaft problems.Thanks in advance for any input on the subject
Chris Heinz
cst 72 blazer is offline   Reply With Quote
Old 03-05-2015, 06:30 PM   #2
cst 72 blazer
Re: Angle plug headers that fit a 4wd?sbc
bump. anybody? shortys will work also
Chris Heinz
Old 03-06-2015, 11:53 PM   #3
tjsblazer
tjsblazer's Avatar
I am using mid-length TriY type. I haven't completed but I test fit on AFR 195 heads with angle plugs. I tried Both Dougs and Doug Thorleys because they were less expensive but both had issues somewhere so I sent them back to Summit.
I got a set of Stan's out of Washington. I bought them in bare metal and ceramic coat locally. They are a little spendy but very well made. You could see the difference over the others I tried and fit well for me. Also had a nice big square port that didn't pinch the exhaust outlet on the AFR heads like the others did.
I think 172YB was the part number.
I talked to them on the phone. The shop foreman/supervisor (can't remember his name) is familiar with this era of truck.
My truck is a 72 4x4 Blazer
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 03-11-2015, 08:25 PM   #4
cst 72 blazer
thank you so much TJ ! got a set on order!
Chris Heinz
Old 06-28-2015, 11:56 PM   #5
tjsblazer
tjsblazer's Avatar
Did you get your Headers in. Here is few pics of mine temp mounted now on the roller. I did have to clearance the top rail of the frame but that is because my Engine is moved 1 7/8" forward and it narrows a bit. I'm going to send them out now for Ceramic coat.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 07-07-2015, 01:12 AM   #6
Blazerowner
Blazerowner's Avatar
I bought Doug's 372Y and they hit the rear spring shackle on the drivers side. $640 headers that don't fit.
Kirk
72 Blazer CST 4wd highlander
Blazerowner is offline   Reply With Quote
Old 07-07-2015, 12:25 PM   #7
Blazerowner
Just happened to notice this tag when packing these back up. Might explain a few things considering they are outsourcing.
Kirk
Old 07-07-2015, 09:13 PM   #8
tjsblazer
tjsblazer's Avatar
Yes, read the reply I just sent to your PM. You are not the first to have Front shackle issues either. I have seen a Blazer in the Restoration forum with the same issue.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
