02-27-2015, 12:19 PM | #1 |
New Member: Calling Bagged Subs/Panels and anyone running 20's (tire Q)
Hey Guys,
Finally ready to start completely redo'ing my chopped '55 suburban I started 20 years ago and finished about 15. Looking to bag it, new wheels, new interior for now...then will go to the motor again and do a turbo LS most likely. Most of the things I wish I had done by the time I was done with the project, but just weren't happening when we started in '95. Have a few questions: 1. Any bagged sub/panel guys here who can show me how you did the back floorboard when completed? One thing I can't lose is back seat space and that's a concern of mine. This thing has two kids seats in it at all times for my 2 and 4 year old (this is the car I got to keep when the kids came)....and my wife uses it for grocery store runs, etc so I can't lose a ton of space. 2. Looking to go 18's upfront and 20's or 22's (most likely 20's) in the rear. The car is tubbed so I can get quite wide but don't want a super low profile sidewall. When we first built it, it was on if I remember 305/50r17's (which they no longer make, so i'm stuck on 285/60's). But I wanted tos ee if anyone is running a 305/45r20 and could show pics, or a 315/35r20.
Chopped '55 Suburban "subhuman" |
02-27-2015, 12:28 PM | #2 |
Re: New Member: Calling Bagged Subs/Panels and anyone running 20's (tire Q)
Also, i'm debating between the Billet Specialty Bonneville G's or the SLD89's. These two have been in my head for almost a decade and I just need to pull the trigger. My boyds are trash, 2 bent, 1 out of round, other one won't balance for sh*t.
I had planned on bagging it first, but the shop I want to do the work is booked up till fall. So I'm going to do wheels first.
02-27-2015, 01:38 PM | #3 |
Realize those aren't the bonnevilles, but the Heritages. Also looking at the heritage S's:
02-28-2015, 11:26 PM | #4 |
Well, I haven't made a wheel selection yet and my Burb is a 48 on bags. I don't know if 20's will fit, though you could take a peak at how I did my floor. I only used a c notch in the rear instead of a kick up. So much yackity yack in my build thread..my fault...you could start at the end and go back a few pages.
Probably someone with a Task Force Burb will weigh in. Chizzler built a very cool AD Suburban with a kick up. He may chime in and I will look for his thread. Youngrodder is going the Porterbuilt route on his AD Burb and has a good build thread going. http://67-72chevytrucks.com/vboard/s...d.php?t=404091 |
03-01-2015, 12:19 AM | #5 |
Thanks bud. Will take a peak. Chizzlers burb is exactly what id do if I did this one over again.
Appreciate the response brother.
03-01-2015, 12:29 AM | #6 |
SAVING ONE TRUCK AT A TIME
On my burb we made the rear floor section out of metal. Im running 6.70-15 firestone white walls.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
03-01-2015, 12:30 AM | #7 |
I haven't dug through the pics yet. How far up did you have to come? Is it flat all out back?
03-01-2015, 12:43 AM | #8 |
Here is what it looks like.
03-01-2015, 11:00 AM | #9 |
Right on. Thanks for the pic!
03-01-2015, 02:33 PM | #10 |
Here is what I did. Added 3 1/2 inches width to the tubs and built the bubble in the middle of the floor for differential clearance when aired out.
03-01-2015, 02:46 PM | #11 |
I like that. Could get away with that one!!!
03-01-2015, 02:53 PM | #12 |
A seat will fit over the bubble and I am not going as low as Chizzler. Just a c notch in the frame.
I believe this one was built with a C notch. The builder also built my chassis. http://www.tricktrucknrod.com/hh/Pro...?productId=247 |
03-06-2015, 08:09 PM | #13 |
Hey HB,
This is what I'm doing. I replaced the floor with new wood. Thought Id just make the hump with wood but really didn't like that look. I had a sheet metal piece made but have to put it in when it warms up. The photo is just to give you some ideas... |
03-06-2015, 10:04 PM | #14 |
theses are a tad bit wider the the 305's but 18's and 20's
03-07-2015, 12:44 AM | #15 | |
dig it, i built out side compartments (one side holds two batteries, the other a compressor, and then storage above). I think i can get away with moving the floor up 12-18". Just need to keep it flat as this thing gets filled with all types of random junk.
03-07-2015, 12:44 AM | #16 |
