Check this out, your welcome :D
Well, I've been back and forth now for awhile on whether or not to undercoat my 67'. Its currently a daily driver, so I should do some kind of corrosion prevention, but I don't want an ugly mess to clean up from a failed cheap bed-liner on it.
So I'm curious, what do you guys do to prevent rust in your undercarriage? Here's my idea, in the Navy I was a jet mechanic. We inspected, tore down, built up, and tested primarily F18 engines on an aircraft carrier. We all know salt water is super corrosive, so we had to put this goopy black crap called grad 4 on certain components that were notorious for rusting. It was messsy, and of-course that gear was always located in the most convenient spots! It was virtually impossible to check, tighten, or work around the engine during testing without getting that crap on your uniform, which doesn't come out...I worked in hazmat when I first got to the ship, so I was very familiar with the the whole process of finding suitable replacements for items that we might run out of while on deployment. So after getting Grade 4 on my uniform for the last time I did some digging and came up with this aerosol spray called "Solid Film" not the same as the product "fluid film" I had to look through some of my old papers to find the identification number for it. You can search it by the "MIL SPEC" or the "NIIN" that ill provide below, and ill put a link to the only site I've found so far that has prices for it posted. It essentially looks like a high quality flat gray spray paint with a super smooth finish. The grade 4 which had the same mil spec but we all hated was an every 3 month job essentially cleaning it off and re applying it. Bustin whatever Rustin was occurring. But when we used the solid film spray, it doubled or more the length of time that they actually needed touch ups. And that's in an environment exposed to all kinds of detergents, jet fuel, and of-course salt spray. I'm pretty sure if its applied to a car it'll last a year or more no problems. That's my theory at least. $40 every 16 oz its an expensive theory but I might have a hook up somewhere...hopefully :P The bottom link tells you all the info on it that you want to know if your a nerd like me and want to know what testing is involved and how well it performed, etc. but for those that don't want to ill post the paragraph from it where it says how long it last in various environments. I'd say its fairly accurate 90% of our gear prolly could have gone 9-10 months without touch ups but it depended on who was applying it and if they cared or not. Good luck, the war on rust never ends! especially if your like I used to be and "spray once for dust and twice for rust" " Corrosion protection life. This lubricant can be expected to provide corrosion protection for five years in indoor storage and approximately two years protection in outdoor storage when the lubricant is applied over phosphated steel to a thickness of 0.013 mm. Where maximum corrosion protection of steel is desired, the lubricant should be applied over phosphated steel to a thickness of 0.025 mm. This heavier coating can be expected to provide outdoor corrosion protection for approximately four years." http://www.skygeek.com/sandstrom-28a...rf-46147d.html http://solidfilmlubricants.com/Specs/L46147C.pdf
"Owning a show quality classic truck and never driving it is like marrying a super model and sleeping in separate beds. Wheres the fun in that?" 1967 Chevy C10 Fleetside 383 Stroker Navy Jet Mech Veteran 2009-2014 OIF OEF OND Last edited by NavyJetMechLegacy; 02-27-2015 at 01:14 PM. |
| Bookmarks |
| Tags |
| underbody spray, undercarriage, undercoat, undercoating |
