Old 02-27-2015, 01:16 PM   #1
Houston Ben
Houston Ben's Avatar
Proportioning valve flare nut sizes
Hi All,
I am going to install the wildwood adjustable proportioning valve in place of my original proportioning valve and I am wondering if anyone knows the original nut sizes? Has anyone one replaced theirs with the same and in the stock location?
Any help will be greatly appreciated.
Houston Ben is offline   Reply With Quote
Old 02-27-2015, 04:11 PM   #2
ray_mcavoy
Re: Proportioning valve flare nut sizes
The original flare nut thread sizes are:
Front inlet = 1/2"-20 nut on 3/16" line
Front outlets = 3/8"-24 nuts on 3/16" line
Rear inlet = 7/16"-24 nut on 1/4" line
Rear outlet = 9/16"-18 on 1/4" line
The front outlets & rear inlet are both standard size inverted flare tubing nuts for their respective tubing sizes. While the front inlet & rear outlet use special over-size nuts.
By the way, the original valve is more than just a proportioning valve.
Its a combination valve that includes a metering valve, a pressure differential warning switch, and a proportioning valve.
ray_mcavoy is offline   Reply With Quote
Old 02-27-2015, 09:41 PM   #3
chengny
chengny's Avatar
Essentially the same info as ray_mcavoy posted above - just shown in one image:
chengny is offline   Reply With Quote
