Old 02-27-2015, 02:10 PM   #1
rs74
rs74's Avatar
90's model seat install video in a square.
If this is not the correct place for this then would someone please move it. Just thought I would share the video I came across. I am thinking about doing something like this in one of my squares. It looks like it could use some tweaking but kind of gives a run down on how to.
https://www.youtube.com/watch?v=a6Hs...I&feature=yout
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 02-27-2015, 02:26 PM   #2
enaberif
Re: 90's model seat install video in a square.
Should be referred to as late 90s as those seats came in trucks from 95+. I personally think they are too big for the truck but install is easy with the bench brackets.
enaberif is offline   Reply With Quote
Old 02-27-2015, 02:30 PM   #3
rs74
rs74's Avatar
I have been thinking about either the 88-94 seat or the 95-99 style. Just a though at the moment. I like my bench but would like something a little more comfortable. Finding one in burgundy might be a little challenge.
Roy
1987 R10 shortie
Old 02-27-2015, 02:35 PM   #4
enaberif
Where I live a guy has been trying to sell a 60/40 bench in burgandy from a 88-94.
I was at the wreckers the other day and they had a mint 60/40 bench in grey. If I didn't have my buckets it would have been gone.
Old 02-27-2015, 02:52 PM   #5
rs74
rs74's Avatar
I have a set of 90 suburban buckets to put in my 85 short bed. This would be for my 84 short bed but I have two daughters that ride in this truck so I need the bench or 60/40 for them which is fine. Would be nice to have an arm rest or console that can flip up if needed. If it wasn't for my girls I would probably put a set of buckets in it. My K30 has a new covered bench in it so no problems there.
Roy
1987 R10 shortie
Old 02-27-2015, 04:41 PM   #6
Jeepwm69
I got a 60/40 out of a 95-96 truck to put in my 83. The drivers part (60) went in easily. Still have to figure something out to put the bucket in on the passenger side.
Heck of a lot more comfortable than the stock seat, and I like the armrest.
Jeepwm69 is offline   Reply With Quote
Old 02-28-2015, 08:55 AM   #7
bluex
bluex's Avatar
I used that method to put a set in mine. It didn't quite work like his did though.
I bought another set of tracks but they were 81+. The wings he cut off are taller on those than a 73-80 set which was on my stock seat. I made it work but it took some extra figuring out. I think they look pretty good and they are very comfortable for sure.
I used the 73-80 tracks on the outsides. The right side 81+ track on the inside of the driver seat an it was unmodified. On the passenger seat I used the left 81+ track and I had to shorten the rear mount on the track by about 1". I couldn't just cut them off like he did. I then cut up the left side mount that came on the 60 seat to make mounts for both seats inside track an welded them to my floor.
bluex is offline   Reply With Quote
Old 03-02-2015, 03:45 PM   #8
Jeepwm69
I used the seat sliders that were already on the 60 portion of the seat. Had to drill holes for the inner bracket, and just bent them a little to fit, and mounted using grade 8 bolts.
The outer bracket on the 60 portion I used a piece of flat steel and bolted it to the factory holes in the floor, and then bolted the 60 seat slider to that flat steel. Now I have a power seat on the drivers side.
The passenger side I still need to install. BlueX, you have any pics of the passenger side on yours?
