Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 02-27-2015, 04:11 PM   #1
gmachinz
NEW 1981-up window/lock harnesses F/S!
I've been building quite a few express optioned harnesses lately and have extended my options to include LH, Center and RH OEM style replacement harness sections. I'll be adding pics soon but for those who would like to get a jump on these, as far as I'm aware of, I am the only person offering these. My harnesses are not just print-pulled kits with all the same deficiencies as GM's original designs-no, I upgrade certain aspects such as:
All terminations are crimped AND soldered then heatshrinked where applicable
Chases through the door jamb boots from cab into doorn shells are protected with an industrial grade abrasion sleeving to not only keep moisture out but to protect the wires and they move every time you open/close the doors.
Larger ground and power leads to switches.
Heat resistant loom to protect wires routed inside door shells.
I'll be adding pricing and more info w/pics shortly so bookmark this thread!
LH harness section $149
RH harness section $129
Center harness section $89
Complete set of all 3, discounted to $339!
Harnesses do not include door boots or power lock relay. They do include:
All correct GM terminals and connectors
Cab harness grommets
OEM connectors to fuse panel and door lock relay (applies to center harness)
Shipping is extra so inquire for a shipping quote.
gmachinz is offline   Reply With Quote
Old 03-05-2015, 11:11 AM   #2
gmachinz
Re: NEW 1981-up window/lock harnesses F/S!
I just finished an set of LH and RH harnesses w/express down option for another memeber-here's a few pics of his set so you get an idea. The express down (and/or UP If desired) is an added cost but I offer reproduction stock oem harnesses as well. These feature upgraded wiring over oem, soldered connections and an abrasion sleeving protecting the wires through the critical boot areas of the door-cab transition. I include extra connectors and terminals too since GM used a few different styles it appears for the door lock cab connection.
Old 03-08-2015, 07:16 PM   #3
chevy-fun
chevy-fun's Avatar
hi gmachinz. im guessing these were mine. the quality is FAR SUPERIOR then factory. i love how you heat shrink wrapped the door an window plugs. from factory they are exposed an after time especially if you remove the panels often they tend to break right before they go into plug.
im guessing i got the left an right harness that i purchased. an see you now make the center piece. please send a pm with price an info
chevy-fun is offline   Reply With Quote
Old 03-09-2015, 01:10 AM   #4
gmachinz
I'm glad you are happy with the harnesses! The heat shrink @ the switch connector locations help prevent moisture build-up inside the terminals. I also use an abrasion sleeving over the harnesses where they rest inside the door boot grommets-this is an area where the wiring gets brittle over time from the constant flexing from the doors opening and closing. I'll PM you about the center dash harness section you asked about-those are available as well!
