02-27-2015, 07:09 PM | #1 |
drop spindle hitting crossmember
72 gmc,stock crossmember,2.5 drop spindle,pbfab upper & lower control arms.How much is safe to trim on the outside of the upper spring pocket ?
84 step side 87 swb |
02-27-2015, 07:17 PM | #2 |
67-72 parts collector,…
Re: drop spindle hitting crossmember
Can you post some pics to explain the problem area?
02-27-2015, 07:21 PM | #3 |
Give me a few.
02-27-2015, 07:42 PM | #4 |
Keith,i'm on IG,calvin78612. Can't upload pics from my phone.
02-27-2015, 07:59 PM | #5 |
I assume those are the PB "narrowed" a-arms?
02-27-2015, 08:00 PM | #6 |
I would trim the just enough of the spindle or the crossmember to clear.
You shouldn't be at full lift like that very often. The spindle casting looks really thick! What brand are they?
02-27-2015, 08:30 PM | #7 |
Mcgaughys 2.5, and the pb are narrowed 1"
02-27-2015, 09:06 PM | #8 |
The narrowed a-arm is getting you close.
Normally the top of the spindle will be nowhere near your crossmember
02-27-2015, 09:26 PM | #9 |
Thanks Keith. That's what I thought.How did you get the pic from IG to here ?
02-27-2015, 09:37 PM | #10 |
I take a "screen picture" with my phone or ipad and save it.
Then I transfer from my phone or ipad.
02-28-2015, 07:52 AM | #11 | |
Love ya man!
02-28-2015, 09:47 AM | #12 |
Just razzing you.... You know a little about how to do everything
02-28-2015, 09:52 AM | #13 |
Instagram doesn't have a feature to "save this image".
So I just take a "screen shot" of the page. Crop out everything but the picture and then transfer using the normal "manage attachments" feature here on the board. I must not be awake yet SCOTI. You had me totally lost. Ha
02-28-2015, 10:18 AM | #14 | |
