Old 02-27-2015, 08:16 PM   #1
Cumminpwr11
Southern Nevada Coal Roller
Large fuel tanks for 3+3 trucks?
I am looking for a crew cab long bed. I am trying to find out about fuel tank size. Does anyone know of a large fuel tank (40 gal) that is available for the trucks.
Chris
Chris
72 Suburban, 1 ton dodge chassis 4wd cummins, DTT 47rh 89%, PDR VE 3200 spring, PODS, Piers Turbo.
36 Chevy P/U rat rod project. 4bta cummins
Cumminpwr11 is offline   Reply With Quote
Old 02-27-2015, 10:14 PM   #2
kevinr1970
Re: Large fuel tanks for 3+3 trucks?
Two 20 gallon tanks.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 02-27-2015, 11:23 PM   #3
Cumminpwr11
I was hoping for twin 35gallon tanks. Maybe I can have a fuel cell made. How tight is it under there? Also is there a way to fill both tanks from the driver side? I don't know much about these trucks.
Chris
Chris
Old 02-28-2015, 12:24 AM   #4
csdineley
csdineley's Avatar
How about 2x 20 gal tanks and a 40 gal suburban tank in the back
87 V20, Vortec 350, Sm465, Np205, Dana 44, 14bff 4.10's
csdineley is offline   Reply With Quote
Old 02-28-2015, 12:43 AM   #5
Titomars
Titomars's Avatar
Man that would be one expensive rig to fill carrying 80 gals of fuel!
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
Old 02-28-2015, 12:48 AM   #6
csdineley
csdineley's Avatar
I agree, but that seems to be what he wants
Old 02-28-2015, 12:53 AM   #7
Titomars
Titomars's Avatar
Yeah I get that. I was just thinking if it were mine.
Old 02-28-2015, 12:10 PM   #8
Cumminpwr11
I have a 2004 dodge that I want to replace. I have a 60gal Titan tank under it and 90 gal in the bed. I don't know why I love having so much fuel I just do. Lol plus it lets me plan my stops for cheap fuel when traveling with the family.
What about fueling both tanks from one side?
Chris
Chris
Old 03-02-2015, 01:40 PM   #9
jjmorrse
My 84 has 2 20 gallon tanks with an aftermarket fill crossover. I believe there was a thread mentioning them somewhere on the forum. It works pretty well, but if it is filled too fast, gas will shoot out of both fillers like a kid drinking milk who just heard a joke.
jjmorrse
86 C30 crewcab big dooley. 454- 400
jjmorrse is offline   Reply With Quote
Old 03-02-2015, 02:11 PM   #10
mckustomfab
my attempt at a write up for swapping in a 40gal suburban tank. Link
1991 Chevy Crew Cab R3500 to V3500 Conversion Project:
Build Thread
Photo Bucket Pics
You cant fix stupid, and stupid hurt! Rules to live by.
mckustomfab is offline   Reply With Quote
Old 03-02-2015, 04:40 PM   #11
Cumminpwr11
Thanks for the info guys it gives me a few ideas.
I will read your link. Are you using twin tanks plus the 40 gal suburban tank? I like have a good range in driving so I can plan my stops according to fuel prices. I travel a lot.
I will do another Cummins swap or a duramax swap in it if I buy the one I am looking at.
Chris
Chris
Old 03-02-2015, 10:51 PM   #12
mckustomfab
I replaced my 2-20gal tanks with a single 40 gal tank. I am running longer rear leaf springs and the front spring hanger had to be moved forward. It would have worked with 16gal tanks but not my 2-20gal. You can do a 25gal or 31gal suburban/K5 tank even easier than the 40gal (I think), the 40gal tank is a tight fit even with a long bed.
Build Thread
Photo Bucket Pics
Old 03-02-2015, 10:58 PM   #13
Cumminpwr11
so two 16 and a 40gal all under the truck? That sounds like a winning ticket! I going to have to think about a 3 way switch to select what tank I am on. My in bed tank just gravity fed the main tank and had a float to stop it from overflowing.
Thanks for the information.
How beefy are the frames? Are the boxed frame? I thought I saw they were c-channel frame
Chris
Chris
Old 03-02-2015, 11:03 PM   #14
mckustomfab
If you are running stock length rear springs you can run 2-20gal tanks plus a rear tank, my set up just would allow it.
The frame rails on the 73-87(91) 1tons are beefier then some but they are still C-channel. They are taller and use thicker material then the 1/2 and 3/4ton frames though.
Build Thread
Photo Bucket Pics
Old 03-03-2015, 01:07 AM   #15
Cumminpwr11
Thanks. I am hoping that the truck I found down in Tucson Az is as good as the photos. It will keep me from cutting up my suburban into a crewcab. I am really wanting a crewcab.
I'm 6'4" and will have the bench all the way back. Can an adult fit comfortable in the back seat? My son is 6'2 and 250lb. I hate moving my seat for him. lol
Chris
Chris
