Old 02-28-2015, 07:05 AM   #1
Burmanater
TH350 electrical connectors?
So a while back I nuked the second and third gears in my 84 c10. Now I'm assuming since all the plugs were there and plugged in that this is the original trans to my truck.
My question is why does a TH350 have a 4 pin connector like a 700r4 on the back above the pan on the drivers side and what is the 2 prong connector up on the passenger side towards the top just behind where the bellhousing ends?
I've never worked on anything besides this that had a TH350 with any kind of electrical wiring to it. The one I'm replacing it with doesn't have any either.
Thanks for any info, really just curious as to why they are there. Doesn't mention either of them in my Haynes manual either.
Burmanater is offline   Reply With Quote
Old 02-28-2015, 07:51 AM   #2
donut
donut's Avatar
Re: TH350 electrical connectors?
Taking a guess here, but could it be a thm 350-c with the lock up converter? Think pre 700-r4. I'm sure more knowledgeable folks will chime in later.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 02-28-2015, 09:52 AM   #3
GRADYS Performance
GRADYS Performance's Avatar
TH350 transmissions were built until 1979. TH350C transmissions were built 1980-86. The TH350C transmissions have a lock up torque converter. That is what the square 4 prong plug is for in the middle of the case. The front electrical connection is for smog equipment or lockup to tell the engine what gear the trans is in. TH350 transmissions and converters have to be kept together, TH350C transmissions and converters have to be kept together. The lockup and non lockup will not interchange between the two. They will both bolt into any vehicle the same as as the mounting items are the same. But you would have to deal with the lockup/non lockup issues if you were to make that kind of swap.
GRADYS Performance is offline   Reply With Quote
Old 02-28-2015, 12:48 PM   #4
Slammed84
Slammed84's Avatar
So you're saying that if one was to come across a TH350 that has an electrical plug on it that you would be forced to use a lockup converter?
That sucks! I got a TH350 in my garage sitting around waiting for a home someday, but im not sure if it has the plug or not.....
84' C-10 Custom Deluxe
97' & 98' C-1500 Silverados
Slammed84 is offline   Reply With Quote
Old 02-28-2015, 02:03 PM   #5
GRADYS Performance
If it has the square 4 prong connector in the middle of the case it is a TH350C. And has to be used with a lock up converter and the electrical system to work the lockup properly.
Old 03-01-2015, 02:59 AM   #6
Burmanater
I got a converter with the trans I bought so I planned on using that. I always keep converters with the trans they came with. I would actually prefer not to have the lockup style converter.
Old 10-09-2020, 03:57 PM   #7
Scott91370
Scott91370's Avatar
Hoping @GRADYS Performance still comes around and is still subscribed to this thread...
Along with the round 2 pin black plug (passenger's side) and the square 4 pin white plug (driver's side) there is a rectangular 2 pin red connector that is supposed to connect to a two port vacuum source. Do you know where this source is located?
Scott
1982 GMC Sierra
Scott91370 is offline   Reply With Quote
Old 10-10-2020, 06:14 PM   #8
hatzie
Moderator
hatzie's Avatar
The TCC vacuum source is ported vacuum above the throttle plates on the carburetor.
It runs from that ported vacuum to the thermo vacuum switch on the water neck.
From there it runs to the purge valve on the charcoal emissions vapor can and wyes through a vacuum delay can to the TCC vacuum switch.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 10-10-2020, 06:44 PM   #9
Scott91370
Scott91370's Avatar
Thanks hatzie!!
Scott
1982 GMC Sierra
Old 10-12-2020, 11:03 AM   #10
GRADYS Performance
Thanks Hatzie, I am familiar with the transmission parts but not as knowledgeable about the different wiring combinations depending on the vehicle it is installed in.
