![]() Join Date: Aug 2014
Drop Control Arms that narrow the track of 3rd gen C10?
Anybody make a drop control arm set for the front of the C-10 that would narrow the track of the vehicle also, even if it is only an 1" or 2 at the most?
And discuss any issues as far as tire rubbing frame if any. I need to narrow the track just a bit for fender clearance just a bit. I have thought about wheel backspacing and am real close, just would like a bit more just for good measure. |
Re: Drop Control Arms that narrow the track of 3rd gen C10?
What's your definition of a "3rd Gen" C10?
1973 to 1987. I have an '81 Chevy frame that the '55 is sitting on. So suspension questions will all be relative to the '81 frame.
Thanks |
CPP sells a drop spindle that helps reduce track width & narrowed a-arms can help even more. Try Porterbuilt or Michigan Metal Works for narrowed arms.
