scarebird brake conversion bracket
I was wondering if anybody has used the scarebird brake conversion kit?
scarebird.com |
Re: scarebird brake conversion bracket
Have not on a truck but just installed on 66 nova and would use it again. The directions are good and the parts they suggest fit right. Only deviation I made was rotors- they suggested using wagoners and milling hub, used bendix and were straight bolt on. Bendix from summit also cheaper by 30 dollars
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
I looked into them before I bought drop spindles.
the only reason I can see to use them on our trucks is if you absolutely have to have off the shelf rotors and do not want drop spindles. you will spend the same on drop or standard height spindles and cpp 6 lug rotors as you will on the scarebird brackets and the oem 6 lug rotors
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies 2004 2500HD utility bed aka Brutus |
Thanks for the input guys
