Old 02-28-2015, 03:12 PM   #1
suburban99
suburban99's Avatar
1962 LSx swap fuel filter question?
Swapping a 5.3 into my '62...have walbro fuel pump mounted on the frame rail with 6-AN fittings to the stock 5.3 fuel line. Will run return line into stock tank behind seat as tank is like new...
What filter (if any) are you running? Basic filter on the suction side or pressure filter on pressure side or maybe sock in tank?
suburban99 is offline   Reply With Quote
Old 02-28-2015, 05:07 PM   #2
solidaxel
solidaxel's Avatar
Re: 1962 LSx swap fuel filter question?
I used a stock Wix filter for a 2003 GMC . I scabbed the old filter from the stock fuel lines and silver soldered steel AN -6 fittings to a section of the stock filter fittings and the cheap Wix filters seem to work fine
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-28-2015, 06:30 PM   #3
mike's1965
Are you going to weld a return bung to the tank?
Could a return bung be welded in the metal plate part of the sending unit next to where the fuel feed line comes out? (so you can take it out and wash off the gas/and fumes, for safety, vs welding on the tank)
mike's1965 is offline   Reply With Quote
Old 02-28-2015, 06:52 PM   #4
suburban99
suburban99's Avatar
It's pretty small diameter plate that the stock sender and pickup goes into....I'll give it a look tomorrow.
My tank hasn't had gas in it since 1998 or so...tank is mint inside and out...
Old 02-28-2015, 06:53 PM   #5
suburban99
suburban99's Avatar
On the suction side of the walbro? Got a pic?
Old 02-28-2015, 07:22 PM   #6
solidaxel
solidaxel's Avatar
I placed it between the tank and the injector rail, I guess that would be the suction side, not the return side.
I did not take any pics
LS 3 4L70E
