02-28-2015, 10:26 PM | #1 |
4 wheel discs master cylinder
What are u guys using for a master cylinder with disc brakes? This is for my one ton.
02-28-2015, 11:26 PM | #2 |
Re: 4 wheel discs master cylinder
Just a thought but a 67 up vett have 4 wheel disc brakes. A booster and master, distribution block would work will have to modify the brake rod off the back of the booster.
Between saying and doing many a pair of shoes are worn out |
03-01-2015, 01:42 AM | #3 |
60-66 Nut
What calipers are you running? Is the running gear all later model 1 ton? If so a typical Corvette master may not have a large enough bore.
03-01-2015, 11:34 AM | #4 |
Front calipers will be stock 73-87 chevy 1 ton calipers. Rear calipers will be whatever comes with the 14 bolt disc brake conversion.
03-01-2015, 10:53 PM | #5 |
From what I have read and researched, one from a 1982 Vette should work fine. 1 1/8" bore should be fine with my power brakes. And the Vette originally had 4 wheel disks, so the reservoirs are sized right. Hopefully, it will bolt up with no issues. And you can get new ones for $25 from Autozone.
03-02-2015, 02:13 AM | #6 |
60-66 Nut
The Corvette's did not have calipers with bores as large as a 1 ton caliper. The Corvette master might work, but you may have to go with a larger bore master, depending on the bore size of the rear calipers.
03-02-2015, 01:22 PM | #7 |
There is a lot of good information about brakes here:
http://www.pirate4x4.com/tech/billavista/Brakes/ About 3/4 of the way down the page is a downloadable spreadsheet to input all of your particular specs. It is only for 4-wheel disc brakes. You can find out how well your plan is going to work before buying parts. |
