Old 02-28-2015, 11:01 PM   #1
dhamilton62
dhamilton62's Avatar
Rear end swap question
Just wondering for anyone that's done a rear end swap, when you re-welded on the perches, did you remove the axles and how did you prevent the rear end from warping from the heat of the welds? Any tips or advice would be awesome as I've heard some horror stories of people messing up their rear end housings doing it wrong. Thanks!
dhamilton62 is offline   Reply With Quote
Old 02-28-2015, 11:12 PM   #2
hotrod66
hotrod66's Avatar
Re: Rear end swap question
I leave my axles in .do small 1 inch welds on one side cool with compressed air then go 180 degrees and do another weld. just keep doing this processes taking your time until you have it all welded up.
Between saying and doing many a pair of shoes are worn out
hotrod66 is offline   Reply With Quote
Old 02-28-2015, 11:28 PM   #3
dhamilton62
Awesome and thanks for the advice! Hoping to get it done soon, just worried about messing anything up. Thanks again for the tip!
Old 03-01-2015, 01:06 PM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Yep, similar to what I did. I put the rear end in and set it up with the u-bolt and pinion angle set. I tacked welded the new perches in and then removed the whole axle. Did the final burn in off the truck. Did about 1", then went to the other side and did the same. Let cool naturally for a minute or so and did the original size again. Bounced back and forth this way until done. I don't like cooling with compressed air or water as it can make the welds brittle.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 03-01-2015, 02:10 PM   #5
gmcdeadhead
gmcdeadhead's Avatar
I welded mine up one side then the other. No problems
gmcdeadhead is offline   Reply With Quote
Old 03-01-2015, 05:58 PM   #6
Joe Pass
Joe Pass's Avatar
Come on...Man....get up here and do it....Your killing me...LOL
Joe Pass is offline   Reply With Quote
Old 03-01-2015, 10:25 PM   #7
dhamilton62
I'm trying to make it up there Joe! Hahaha, I'd rather drive up and just hang out and talk trucks than drag you into my mess of a truck! But maybe after I get my front end rebuilt and ready to go, I'll take advantage of your over the top kindness and make a mess of your clean shop! HAHA
Old 03-01-2015, 11:17 PM   #8
Joe Pass
Joe Pass's Avatar
I'm just rattling your cage...but seriously If I can assist don't hesitate...This week I'm installing a Eaton Posi that I found...
Joe
Name:  62 chevy 008.JPG
Name:  62 chevy 012.JPG
Name:  62 chevy 015.JPG
