Rewiring truck - Looking for Diagrams
I am going to be using a universal 21 circuit harness to rewire my 62 C10. I am going this route as I have a lot of non stock things to power and this harness will allow for it (Electric Water Pump, Electric Fan, Electric Fuel Pump, 2 stages of N20, Trans Brake, Line lock, etc).
The big things I need are: Headlight switch pin outs Ignition switch pin outs Colum Pin out for brakes/turn signals I would appreciate any info on these. Thanks in advance!
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 02-28-2015 at 11:22 PM. |
Post Whore
![]() Join Date: Mar 2013
Re: Rewiring truck - Looking for Diagrams
Simple way would be to google a 66 chevy truck wiring schematic. Your wiring harness should be labeled as to what is what.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
Try this. I found it in a google search
Glenn Korec Jamesville NY 64 C20 350ci Turbo 350 tranny 3.73 gear with air ride. 61 Apache10 (wife's truck) 327ci powerglide. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=570100 |
and a few others
Look at post #2 here:
http://67-72chevytrucks.com/vboard/s...d.php?t=646002
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
If you want something you can actually hold in your hand and read easily I would recommend this. It is a reprint of the original books from Chevrolet. I have one of their wiring diagrams and it was a life saver.
What I really need is a diagram of the individual switches, what terminal is for what. Saw one fire the headlight switch and will dig through to see if I can find ignition and column.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
In the links provided, I found Headlight switch and Ingnition pin outs.
I still need to understand the column pins. I had a diagram some time ago but can not find it now. If anyone has this one, that would be greatly appreciated.
I'm just glad to be here!
Here is what I have for the column pins. This is for the 7 or 8 position curved shaped connector.
Terminal, color, function G, Black, Horn Switch (one source has this as a Dark Green wire in 1960-1963 GM Trucks) H, Lt. Blue, Left Front Turn Signal J, Blue, Right Front Turn Signal K, Brown, Hazzard (1960-1966 GM Trucks do not have this wire) L, Purple, Turn Flasher (one source has this as a Yellow wire in 1960-1963 GM Trucks) M, Yellow, Left Rear Turn Signal (one source has this as a Pink wire in 1960-1963 GM Trucks) N, Green, Right Rear Turn Signal (one source has this as a Purple wire in 1960-1963 GM Trucks) P, White, Brake Switch for your 1962 column, the colors should be the ones that are in the (notes) for those functions. GM did change some colors in the column harness for the '64-'66 trucks. If this does not match your pin locations on you connector, the colors should match up with the function...
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square Last edited by aggie91; 03-03-2015 at 04:04 PM. Reason: added year notes to some wires.... |
Thanks Aggie, but I actually need the triangulated one. Pic attached
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
colors are all the same bud.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
I can't go off the colors. There was no factory connector on it, and someone had previously rewired it with none stock wire.
I really need the pin out / function.
60-66 Nut
![]() ![]() Join Date: Mar 2007
Can you unscrew that connector from the column and see what color the wires are on the backside? GM is usually good about maintaining the same color wires on both sides of connectors. Then by wire color you should be able to determine the function of each wire.
Of course a '62 wiring diagram would be most useful, but I don't have one and so far no one that has one has come along.
#13 |
Never seen a connector like that on one of these trucks. It only has 6 positions...
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#14 |
60-66 Nut
The '60-'62's are different than the '63-'66's
#15 |
#16 |
Thanks aggie91!! I'm rewiring MY 62 using American Autowire Power Plus 13 (Universal) harness and although feeling a little overwhelmed at first, its been going quite well....until I got to the turn signal switch. I was unsure how to go about using the new switch connector with the old style connector. After a couple hours of searching my wiring diagrams and finding this thread, I'm simply cutting the new connector and rewiring to the old connector. It should look factory when I'm done.
When was the last time you did something for the first time? We never really grow up, we only learn how to act in public. ![]() |
#17 |
LMC now has a full complement of harnesses and reprinted diagrams.
