Old 08-26-2003, 11:11 AM   #1
ginter
ginter's Avatar
T400 Speedo gear question
I'm replacing the rear tailshaft housing and speedo gear/housing on my 67 w/T400. I'm going from a 37 tooth speedo gear/housing to a 45 gear/housing.
Question: Does the speedo drive gear on the trans output shaft need to ve replaced also?
ginter is offline   Reply With Quote
Old 08-26-2003, 12:04 PM   #2
JimKshortstep4x4
Talking
If you have the right housing, your 45 tooth gear will work with the gear on the shaft.
Jim
Old 08-26-2003, 12:14 PM   #3
ginter
ginter's Avatar
That's what I thought since the offset is different on the housing. Local tranny shop that is going to replace the bushing in the tail shaft housing confirmed this as well.
Thanks!
