Old 03-01-2015, 10:46 AM   #1
TexasStepside
Swapping Turbo 400 in 1980 Stepside
Question - I have swapped a 454 into my 1980 Stepside that was originally a 250/TH350 combo - I retained the TH350 just to get the truck mobile. I want to swap in the TH400 that came with the donor truck (1978 1/2 ton, LWB) but I noticed that the carrier (center) bearing for the two piece driveshaft from the donor truck mounts to a crossmember that also doubles as the rear cab mounts - my Stepside does not have this crossmember, but rather just the mounts for the rear cab. I am planning to transfer this donor truck crossmember and shorten the piece of the driveshaft from the carrier bearing to the rear axle. I am assuming that this is the way the factory setup is with a TH400 in a SWB truck. Any information, pictures of this would be appreciated.
TexasStepside is offline   Reply With Quote
Old 03-01-2015, 11:32 AM   #2
greg64
greg64's Avatar
Re: Swapping Turbo 400 in 1980 Stepside
Well, there may be other opinions on this, but here's mine. The swb trucks don't need a two piece driveshaft. If I were you, I'd get a new shaft made with the turbo400 yoke on one end, and the necessary axle ujoint on the other. Leave the lwb crossmember out.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 03-01-2015, 02:14 PM   #3
Slammed84
Slammed84's Avatar
Just what greg64 said!
I robbed my 400 from a c20 also. I went to a salvage and got a LWB driveshaft and had a local driveshaft shop frankenstein one together for me. They just shortened it and put the 400 yoke on it.
84' C-10 Custom Deluxe
97' & 98' C-1500 Silverados
Slammed84 is offline   Reply With Quote
Old 03-01-2015, 03:23 PM   #4
Titomars
Titomars's Avatar
Actually you do. The crossmember is the same your truck. It just does not have the center support bracket on it. if you were to look closely you should see 4 holes in it where the bracket goes. With that said SWB trucks with automatics did not use 2 piece shafts. The correct TH400 in a SWB 1/2ton is a long tailshaft with a 32 spline slip yoke. The C20 and C30 used a short shaft with bolt in yoke. The short shaft TH400 will work. With a slip yoke or if you use the bolt in yoke you just have a drive shaft made with a slip yoke in it instead of the trans.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
Old 03-01-2015, 04:35 PM   #5
TexasStepside
Titomars - thanks for the response - I notice that you have a 77 stepside with a factory 454/TH400 - any chance of getting some pictures of the setup of you have? Thx
Old 03-01-2015, 06:51 PM   #6
Titomars
Titomars's Avatar
I can take some pics for you. Mine is not 100% stock/correct yet. When I bought her the original owner swapped in a 700R4. Which proceeded to get blown up. The original TH400 was long gone. When I bought it I dragged it home. I bought a TH400 off C/L. but it is a bastard build. A 4X4 case with a car long tail housing and shaft, and no provision for a speedo. Working on finding the correct TH400 for mine.
Old 11-21-2015, 01:15 AM   #7
snaptoo
My trans guy built me what he called a TH 375 , used a BOP output shaft and housing and uses a small dia. yoke but it was a long slip really worked out well !!
snaptoo is offline   Reply With Quote
Old 11-21-2015, 07:54 PM   #8
USSkoval
There's more than a couple ways to skin this cat.
I replaced my shortbed's th350 with a th400 from a heavier truck (short tail, bolt-on yoke). I simply used my stock th350 shaft with a long slip style yoke from a 4x4 Burb (had the np208). I also unbolted the fixed yoke that came on the th400. It worked out perfect, the longer yoke made up the difference of the shorter trans and it slid right into place.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
