Old 03-01-2015, 04:44 PM   #1
hardwaycooke
hardwaycooke's Avatar
Help switching from 2BB to Quadrajet??
My buddy has a 2bbl 350 on a 70 c10. Like to know all the parts needed to do the swap. I have a 4bbl quadrajet manifold I am giving him. What else does he need?
Which Quadrajet do we use??
71 LWB
Large Bore 6-71 Blown 383 Stroker
4.11 Motive/EOM Eaton Posi Ported/Polished Carrier
15x8/15x16.5 MT Radials
B&M Pro Shifter
Truck Name- Spike
hardwaycooke is offline   Reply With Quote
Old 03-01-2015, 10:11 PM   #2
truckster
truckster's Avatar
Re: Help switching from 2BB to Quadrajet??
It's been a while for me, so I can't remember exactly what besides the manifold and carb have to change - just compare the linkages and you should be OK.
As for the Quadrajet, go with a later-model Quadrajet with the electric choke. It will make setting it up easier and they're very dependable.
truckster is offline   Reply With Quote
Old 03-02-2015, 10:43 AM   #3
Lou Boffa
Lou Boffa's Avatar
subbed
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline   Reply With Quote
Old 03-02-2015, 11:31 AM   #4
JJLT1
JJLT1's Avatar
RTV, gaskets, air cleaner/base, 3/8 fuel line/fitting, choke/power or linkage or tubes..
don't get the E4MC/E Qjet with the elec plugs on the top and front..
one like this would work, has a hot air choke
http://www.ebay.com/itm/Rochester-Qu...item20f75378d3
call him and ask, he can change the choke to elec..
http://stores.ebay.com/Mountain-Man-...=p4634.c0.m322
JJ
71 SWB 360 Th400 4.56
JJLT1 is offline   Reply With Quote
Old 03-02-2015, 08:37 PM   #5
hardwaycooke
What about kickdown, throttle cables?? Are they the same? Thanks
For electric choke, can we just run a wire to a 12 v wire to the fuse box?
71 LWB
B&M Pro Shifter
Truck Name- Spike
Old 03-02-2015, 11:27 PM   #6
racerface
throw the Quadrajunk away and get a throttle body fuel injection. Less hassel, better fuel management and MPG.
Racerface
Wellington, Ohio Freedom Isn't Free!
GO BUCKEYES!!!
Toys: 68 C-30 327-400turbo
68 C-30 Open Road Camper 327-400turbo
81 GMC Sierra 1500 250-350turbo Long Bed
83 K-10 4X4 Scottsdale
racerface is offline   Reply With Quote
Old 03-03-2015, 12:11 PM   #7
JJLT1
JJLT1's Avatar
kick down depends on what trans?
throttle cable depends on the intake and carb and bracket, year models are different?
youll probly need to mod the bracket,, move it forward or get one for a qjet.
some aftermarkets are really adjustable,
but the thin ones tend to bend if you have a stiff spring?
I have not tried this one.. it also depends on the trans/cable..
http://www.summitracing.com/parts/spe-24283/overview/
heres some pics
http://www.bing.com/images/search?q=...cs&FORM=HDRSC2
some people do run the choke power from the fuse box, lots of ways to do it..
electric choke would need a 12v, key on, fused circuit, I think the choke is a about 20a fuse.
it would be good to use a separate circuit, and a relay,
depending on other loads, older cars are kinda limited on how much stuff you can add..
I would not run the extra power thru the ignition switch/fuse box,
but triggering a relay with it is ok, takes very little power..
the later models run the choke thru the oil pressure switch too,
so the choke heater wont come on till the engine is running..
JJ
Old 03-03-2015, 12:58 PM   #8
Coley
Coley's Avatar
....or just buy a new Toyota...super reliable, really economical and....new. LoL
All Good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
