Old 03-01-2015, 08:49 PM   #1
Possmguts
Possmguts's Avatar
let me see your 5 1/2 x 5 inch static drop
Let me see your 5 1/2 x 5 inch static drop and tell me what size tires and wheels you're running. I need to see them to get a feel for what size tires and wheels I will need to go with. Ill be getting my frame to roller status maybe next week but will not have any weight on it for a while, so I have no idea what to really expect.... and if you did or dint do a C-notch... if not do you bottom out against the frame at all? Thanks!
Dont forget to give your specks on the drop and tire and wheel size please.
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 03-05-2015, 05:43 PM   #2
Possmguts
Possmguts's Avatar
Re: let me see your 5 1/2 x 5 inch static drop
Come on... no takers here?
Old 03-05-2015, 07:42 PM   #3
Mike C
Mike C's Avatar
You are asking for a combo that most likely nobody runs. 4 1/2"-6" drop, 5"-7", 2 1/2"-4". My own truck is 4 1/2" - 7" with a leaf spring flip. But nobody does a 5 1/2" -5" drop which is odd for one of these. Too much in the front and not enough in the rear. Here's my 4 1/2" -7". My short step has about as big a tire as you can get on a stepside without bed mods. 275 55 17 on 17x9" wheel with 5" backspace using a 72 width axle. The front is 235 55 17 on 17x8" wheel with 4.5" bs.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Mike C is online now   Reply With Quote
