Pump to Carb Fuel Line
Does anyone know if the 67-72 292 pump to carb fuel line will fit '73-newer trucks? I've looked everywhere for one but can only find pre-'73 line. I see no reason why it wouldn't, but I'd like to be sure.
Thanks.
Fred 1974 C-20 Fleetside White/Crimson Red 292/SM465 4.10:1 open 1976 AMC/Jeep CJ-5 Lime Green 258/T150 3.54:1 open 1972 C10 Suburban - SOLD White/Medium Spruce Metallic/White Avocado Highlander Pkg 402/TH400 3.08:1 open |
Re: Pump to Carb Fuel Line
I think it should but have no idea really.
Contact Inline tube. They can manufacture anything you need. http://www.inlinetube.com/
Very familiar with them...good Jeep products. I'll try them, thanks.
Hey Fred, as long as both engines were using Rochester carbs, the fuel line ought to fit. The pumps are in the same place on all 292s (interestingly enough, a different place from the 230/250).
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
I just use rubber fuel line. I know Not as safe But you can run it easier away from any thing hot and i think it helps keep fuel from getting hot adding to vapor lock.
83 c10 long Box Daily Driver 90 Jimmy parked 98 Road King/ 06 Road Glide In memorium 63 impala SS/ 65 Chevy Panel 65 GMC Short Box/ 68 Camero |
That's what I was thinking too. Makes me wonder why they label it '67-'72... I'll get one and report back.
But if the hose happens to rub on something, or it fails from ethanol (which I've seen happen), you run the risk of fire, and I have an aversion to blowing up.
| Bookmarks |
