Old 03-02-2015, 02:05 AM   #1
775stepside
89 2wd silverado 350: sensor identification
Trying to figure out what sensor is the one that is on the manifold next to the thermostat housing? Is it the water temp sensor? I picked one up from the auto parts store and the connector doesn't fit? It seems like the connected is broken? I'm not sure though can someone chime in?
775stepside is offline   Reply With Quote
Old 03-02-2015, 06:29 AM   #2
Re: 89 2wd silverado 350: sensor identification
From everything I remember, the water temp is in the driver or passenger side head, not the intake manifold. I'll look at the 94 later when the sun is up and see if it rings a bell with me.
Old 03-02-2015, 06:49 AM   #3
95 S_Trucker
95 S_Trucker's Avatar
The coolant temp sensor for the ecm/pcm is right next to the thermostat. The coolant sending unit for the gauge is in the drivers side cylinder head between the 1 and 3 exhaust ports.
95 S_Trucker is offline   Reply With Quote
Old 03-02-2015, 07:38 AM   #4
BigBlocksRule
Sounds like you got the gauge sensor, you're asking about the one for the computer.
SAVE THE OLD ONE! If the computer temp sensor ever takes a crap, it'll make your engine run very rich, the computer will think it's waaay cold and try to warm it up. Take the spare you saved out of the glove box and plug it in, don't worry about screwing it in until you have the proper tools and time. Leave the sensor laying on the intake, it will correct the problem if that sensor goes bad.
BigBlocksRule is offline   Reply With Quote
Old 03-02-2015, 02:30 PM   #5
775stepside
No I must of got the right one but the connector doesn't hook up to it, it has 2 pin connections, and the one for the guage on the side of the head looks similar to oil pressure, u just slide the connector over it. The problem I'm having is if there's another type of sensor that goes on the manifold because my connector seems to be just round and flat at the end.
Old 03-02-2015, 04:24 PM   #6
speedygonzales
speedygonzales's Avatar
Look like this?
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
Old 03-02-2015, 05:32 PM   #7
775stepside
Yea it does but my connector is round It won't go inside the mushroom thing inside
Old 03-02-2015, 06:11 PM   #8
speedygonzales
Put a picture up of your original sensor
Pride and joy
Old 03-02-2015, 06:55 PM   #9
BigBlocksRule
Or connector
Old 03-02-2015, 07:58 PM   #10
775stepside
Fixed thanks guys
Old 03-02-2015, 09:14 PM   #11
BigBlocksRule
Oh, man, you can't leave us hangin' like that
What was it?
Old 03-02-2015, 09:25 PM   #12
775stepside
Haha give me a break ok, so on the connector side the top part of the sensor broke off and I looked at it and I thought it was the actual connector, until I really looked at the sensor and saw it was broken off and I pulled the broken piece off the connector.
Old 03-03-2015, 06:55 AM   #13
BigBlocksRule
Cool. We've all had something similar happen to us.
Glad to hear you got 'er fixed!
