Old 03-02-2015, 03:39 PM   #1
RB72
4x4 Wheels
I am looking for some wheels that will raise my truck an inch or two... Does anyone know what the biggest size wheels and tires you can stick on a 72 without having to change anything? And what are some good looking wheels that would look good on this truck?
Thanks, Ryan!
RB72 is offline   Reply With Quote
Old 03-02-2015, 03:59 PM   #2
enaberif
Re: 4x4 Wheels
What are you running now? You could go with a 255/85/16 which will lift you up a bit but still remain skinny enough to turn
enaberif is offline   Reply With Quote
Old 03-02-2015, 04:10 PM   #3
RB72
Re: 4x4 Wheels
Not sure what they are now. I just bought the truck and they have a later date rally wheel on it.
Old 03-02-2015, 04:13 PM   #4
RB72
Re: 4x4 Wheels
I think they may be a 235
Old 03-02-2015, 04:19 PM   #5
enaberif
Re: 4x4 Wheels
Looks like 235/75r15?
Old 03-02-2015, 04:25 PM   #6
RB72
Re: 4x4 Wheels
Yup they sure are.
Old 03-02-2015, 06:21 PM   #7
Mike C
Mike C's Avatar
Re: 4x4 Wheels
You should be able to run a 33" tire with no problem with no lift. I would use an 8" wheel so either a 33 10.5 15 if you stay with 15's (I would go to 16's or 17's personally). A 265 75 16 or a 265 70 17 is a 32" inch tire. Would work good on an 8" rim.
A 255 85 16 would work as well and would be a little narrower and a little taller (33" 10.5 16" effectively)
Personally I like old school rim designs. I like the Alcoa style rims or a Centerline in that same. I put the American Racing black teflon wheel on my Duramax (the one with the 8 big holes in it) which I like.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-02-2015, 06:23 PM   #8
RB72
Re: 4x4 Wheels
Sweet thanks! That helps A LOT!
Old 03-03-2015, 12:39 AM   #9
Re: 4x4 Wheels
Sounds like you need tires not wheels. Wheels do nothing for ride height. That's in the suspension and tire diameter. You can get 33s on there, as mentioned, so 12.50s or 10.50s will go on your rallyes. Freshen those up and you have a good looking wheel that's hard to beat at 3x the cost
Old 03-03-2015, 01:01 AM   #10
RB72
Re: 4x4 Wheels
Very true. Didn't think of that. Thanks for the help guys!
Old 03-03-2015, 03:49 AM   #11
RedRoad
RedRoad's Avatar
Re: 4x4 Wheels
255/85/16 on a stock steel rim will only measure 32 inches tall installed, less on a wider rim.
RedRoad is offline   Reply With Quote
Old 03-03-2015, 04:04 AM   #12
jjzepplin
jjzepplin's Avatar
Re: 4x4 Wheels
This is a good idea! And you might think of some longer close ended type lug nuts that not only look better but when you need to change a tire you can actually reach them with your lug wrench without having to take the center cap off. Roadside anger sux.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
