Old 03-02-2015, 04:11 PM   #1
62step
Motor mount questions
Hey guys,
I've done some searching and saw that I would need a 1" spacer for the motor mounts (I have a 72 front crossmember on a 62 frame). If I read it right I would need a motor mount kit for a 72 truck and then I just get some 1" spacers, right?
Stock was a 283 v8 and I'm putting in a sbc 350 with a 700r4..
Sorry if I answered my own question, just want to make sure before I go out and buy a motor mount kit.
62step is offline   Reply With Quote
Old 03-02-2015, 04:39 PM   #2
64tantruck
64tantruck's Avatar
Re: Motor mount questions
Correct. We have a 79 crossmember installed in our 61. We needed spacers on the top of the frame rails. (the frame rails on the 60-62 are shorter) I had a local guy down the street cut some 3/4 inch spacers out with a plasma cutter. Hope this helps.
Glenn
Glenn Korec
Jamesville NY
64 C20 350ci Turbo 350 tranny 3.73 gear with air ride.
61 Apache10 (wife's truck) 327ci powerglide.
http://67-72chevytrucks.com/vboard/s...d.php?t=570100
64tantruck is offline   Reply With Quote
Old 03-03-2015, 07:58 AM   #3
62step
Thank you, now for the mounts that go onto the motor it self. I just say i.e. 79 v8 motor mounts?
Old 03-03-2015, 02:00 PM   #4
par4tom
I have a 61 and did some searching here in the forums to get my ideas. Really, there were not any surprises. I used the 67-72 motor mounts (got them at a junk yard for 50 bucks I think). Had some half inch aluminum metal which I just cut on my table saw to the right size, double stacked them and then drilled a couple of holes. Pretty easy!
Oh...and before you tighten every thing down, get the motor and the mounts mated up. You can tighten everything on the frame last...
Tom
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=705185
How to Get Audiophile Sound in 60-66 Trucks
http://67-72chevytrucks.com/vboard/s...=1#post7236896
Building Your Own Speaker Kick Pods
http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495
par4tom is offline   Reply With Quote
Old 03-03-2015, 05:32 PM   #5
Joe Pass
Joe Pass's Avatar
Tom
Nice detail work
Joe Pass is offline   Reply With Quote
Old 03-03-2015, 06:10 PM   #6
par4tom
Thank you Joe. I really like what you did on your truck!
Tom
My Build Thread
Old 03-03-2015, 07:15 PM   #7
64tantruck
64tantruck's Avatar
A few pics of our mounts
Glenn Korec
Jamesville NY
Old 03-03-2015, 07:19 PM   #8
Joe Pass
Joe Pass's Avatar
That's pretty nice also.....I do like finished inner fender wells
Old 03-04-2015, 08:51 AM   #9
62step
par4tom, I have those mounts that go on frame already, but I need the part number or something for the mounts that go onto the motor.. I search 78 c10 v8 mounts, but I don't think they look the same.. Probably just me though.
I guess I should search for 67-72 motor mounts for the block?
