Old 03-02-2015, 05:12 PM   #1
gono
gono's Avatar
Amp to volt meter DIY
It's been done a few ways but here's my version. (couldn't find any BIGGER pictures)
Parts list:
volt gauge Summit Racing EQU-7268 $17
2 4-40 X 1 1/2" machine screws
2 plastic washers
6 nuts
6 flat washers
Started by tearing the new gauge apart. Rather than risk breaking the needle off, I cut out the gauge face.
I drilled out the rivets on the old amp gauge and removed the faceplate.
I used the vise and hammer to flatten out the faceplate.
There's two electrical tabs that insert into the back of the gauge. I removed them and double bent them for better clearance through the backing plate.
I drilled mounting holes in the faceplate and attached the screws and washers.
The back of the mounting plate needs to have a larger hole in it so the leads will exit.
I added the second set on mounting screws to adjust how far away the gauge will mount.
Here's the gauge with 12 volts.
Final piece mounted with new sticker.
55' 3100 big window
gono is offline   Reply With Quote
Old 03-02-2015, 06:06 PM   #2
Northern lights
Re: Amp to volt meter DIY
Great tutorial. Thanks for sharing.
Northern lights is offline   Reply With Quote
Old 03-04-2015, 12:28 AM   #3
Daze57
Daze57's Avatar
very nice idea!
Daze57 is offline   Reply With Quote
Old 03-04-2015, 01:59 AM   #4
Softpatch
Softpatch's Avatar
liked your thread thanks for the pictures...Sp
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 03-04-2015, 09:39 AM   #5
Russell Ashley
Russell Ashley's Avatar
Good job on the conversion. Did you reverse the position of the temp and volt gauge?
Russell Ashley is offline   Reply With Quote
Old 03-05-2015, 12:34 PM   #6
gono
gono's Avatar
I don't think so. Im pretty sure I put the fuel sticker on the temp gauge though..
55' 3100 big window
Old 03-06-2015, 11:15 PM   #7
tmoble
calibrate your own temp gauge with that blue resistor?
I actually added a resistor inline in the wire to the sender to get mine to read like a I wanted.
tmoble is offline   Reply With Quote
Old 03-07-2015, 12:08 AM   #8
gono
gono's Avatar
I bought the temp gauge from LMC, but I did put a resistor inline for the fuel sender to get within range.
55' 3100 big window
