Old 03-02-2015, 08:01 PM   #1
joecaruso
joecaruso's Avatar
3 ontt shifting into reverse
I am a relatively new owner of a 1970 c10 with a 402 BB and a three on the tree. When shifting into reverse I need to shift into first and then to reverse in order to avoid grinding gears. Without doing it the shift to reverse is harsh but when I do it shifts fine. Is this normal for this transmission or is it something I should look into?
joecaruso is offline   Reply With Quote
Old 03-02-2015, 09:51 PM   #2
hamjet
hamjet's Avatar
Re: 3 ontt shifting into reverse
Sounds like drag on the Input shaft. Is the clutch disengaging all the way?
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 03-02-2015, 10:00 PM   #3
joecaruso
joecaruso's Avatar
Clutch is depressed all the way but that something to check before getting the truck back on the road in the spring.
Old 03-03-2015, 07:03 PM   #4
northerngmc
northerngmc's Avatar
Try adjusting the shifter and making sure it is aligned. I had a 69 with a 3 speed and after doing this is shifted better.
http://67-72chevytrucks.com/vboard/s...hlight=shifter
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 03-03-2015, 09:10 PM   #5
GRX
GRX's Avatar
This shifter adjustment thread may help.
>> http://www.67-72chevytrucks.com/vboa...d.php?t=215307
GRX is offline   Reply With Quote
Old 03-03-2015, 09:21 PM   #6
joecaruso
joecaruso's Avatar
I did do these adjustments when I bought the truck and they definitely got rid of a lot of the slop in the steering but did not change anything with reverse.
Old 03-03-2015, 09:46 PM   #7
Chucks72Longbed
Chucks72Longbed's Avatar
I had a three speed on the column in the past and it had the same issue. Turned out the businhigs for the linkage in the column were worn out. I just changed it to a hurst floor shifter but I think you could pull the column out, tear it apart and rebuild it. My grinding was like it was trying to go into reverse and 2nd at the same time. Just a thought.
72 Chevy C20 LWB-Just what I always wanted.
Now, just need more time and money!
Chucks72Longbed is offline   Reply With Quote
