Old 03-03-2015, 09:03 AM   #1
dme922
dme922's Avatar
Which core support mounts do i use?
Im converting my 71 gmc to a 68 Chevy K10 and i already have the 67-68 core support. Chassis is a 72 K10. Which core support mounts? 67-68 or 69-72.
dme922 is offline   Reply With Quote
Old 03-03-2015, 09:39 AM   #2
Re: Which core support mounts do i use?
67/68. You go with which core support you are using
Old 03-03-2015, 09:41 AM   #3
dme922
dme922's Avatar
Thanks.
Old 03-03-2015, 02:00 PM   #4
72MARIO
72MARIO's Avatar
Other than they will fall thru the rad support hole on a 69-72 frame.,.... You going to need to weld it up smaller to accommodate the 67-68 mounts
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
