Old 03-03-2015, 01:26 PM   #1
Larry64
Hood lower front replace
Are there any pictures on how to remove & replace the hood lower valance?
Thanks Larry
Larry64 is offline   Reply With Quote
Old 03-04-2015, 12:20 AM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Hood lower front replace
no pics, but it is spot welded on, some you can get to , some you cant... I would cut the piece you are going to replace off your hood, about 1/2 inch from the seam, then you can get to all the spots, and drill them out.. after that you could re spot weld the new piece to your hood, or you might be able to just bolt it on...
Old 03-04-2015, 05:41 PM   #3
Larry64
jonzcustomshop. If you have to cut up the valance to get to the rivets, how do you spot weld the new piece in?
Thanks Larry
Old 03-04-2015, 10:43 PM   #4
Budman56
Budman56's Avatar
here you go
http://67-72chevytrucks.com/vboard/s...d.php?t=641220
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 03-04-2015, 10:46 PM   #5
Budman56
Budman56's Avatar
Here is another one
http://67-72chevytrucks.com/vboard/s...d.php?t=415609
MY 65 C20 BUILD
Old 03-05-2015, 04:33 PM   #6
Larry64
Thanks Budman. What options besides gluing the piece back on are there?
Larry
Old 03-05-2015, 04:44 PM   #7
jhrusk
I replaced mine on my hood that is in my thread
check out SANFORD build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=522019
jhrusk is offline   Reply With Quote
Old 03-05-2015, 05:48 PM   #8
Larry64
jhrusk that is exactly what I need. You have some impressive skills.
Thanks Larry
Old 03-05-2015, 07:32 PM   #9
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I think a new glass hood would be easier!! Im in that same boat now and need to do some repairs to mine.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 03-05-2015, 08:43 PM   #10
nhr3
nhr3's Avatar
I did mine. It was not near as bad as floor and rocker replacement. Just went slow. I looked at it that I could not screw it up any worse than it was. I am real pleased with the results.
65 C10 Short bed, Fleetside, small back window
Build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=619304
nhr3 is offline   Reply With Quote
Old 03-05-2015, 09:22 PM   #11
jonzcustomshop
1961 crewcab
Larry
you might be able to get an actual spot weld gun in there...
you would have to talk to a welding , or body shop, and see if they have one that fits...
