Old 03-03-2015, 07:41 PM   #1
Tree-50
No-limit rear shock mount
I'm going to go with this one mainly based on the fact I don't have the crossmember for the stock location fully intact since I'm going step notch route for the future plans. I like the way it mounts to the side of the frame and seems really easy to install.
My question is does it maintain stock length or should I be doing more math? (I guess it's 2 pieces so you could run whatever lenght you wanted huh? But you should still understand my question)
I thought the point of relocator brackets were to run stock shocks and still get max drop/lift from it? I don't want to buy shocks and then realize I am cheating myself an inch or two.
Suspension set up is
front: 2.5" drop spindle, 2.5" boxed lca, stock uca (might pie it if you think it would help go lower from bind. Not sure how to tell)
rear: bag over axle, step notch. Brothers bolt on shock relocator
Thanks in advance.
Tree-50 is offline   Reply With Quote
Old 03-03-2015, 10:19 PM   #2
PGSigns
PGSigns's Avatar
Re: No-limit rear shock mount
The point of relocators is to correct the shock angle issue created by lowering the vehicle. You still may need to run a shorter shock. I would contact Rob and let them know what setup you are planning and get his shock recomendation.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-03-2015, 10:48 PM   #3
Tree-50
Jimmy
I just actually did that. and that makes more sense to me too about the relocators. I will probably end up just buying their b length since I will be going more than 5" lower in the rear. Now i'm trying to figure out if I want the cpp deluxe trac bar or the ece super track.
Old 03-04-2015, 12:28 AM   #4
65Gregg
65Gregg's Avatar
Rob used to give a slight discount on his panhard if you buy the shock relocation kit.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 03-04-2015, 12:53 AM   #5
Tree-50
Sweet, I was hoping they had some sort of "kit." I liked their design a little more, seems easier to center/level than the cpp. Prices are almost the same as well.
Old 03-04-2015, 01:06 AM   #6
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: No-limit rear shock mount
I can't say enough about it. Very nice kit.
Here is mine.
http://67-72chevytrucks.com/vboard/s...d.php?t=608949
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-04-2015, 08:37 AM   #7
Tree-50
Here is mine.
I kept seeing yours posted every Andy, one of the reasons I want it, looks really nice and clean. My only worry, hopefully rob can help me out on, is the scrubline.I read in another thread 17"+ wheel or you'll have possible issues..hopefully that's not true.
