Old 03-03-2015, 10:13 PM   #1
Backnblack67
5 lug or 6 lug
Ok I have 67 all original I was fixing to put disk brakes on the front . I have a 5 lug rear setting around . What is the advantages of swapping to 5 lug other than than a few more wheel designs .
Backnblack67 is offline   Reply With Quote
Old 03-03-2015, 10:14 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: 5 lug or 6 lug
Since you can get 6 lug rotors for a disc brake conversion up front... nothing really.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 03-03-2015, 10:21 PM   #3
Backnblack67
Re: 5 lug or 6 lug
I might be wrong but I think I read some where that rear end in this model truck was a little narrower would this let me put a little wider tire on back . I am planning on doing a 4/6 static drop on it also . That is one reason I was wanting to leave 6 lug unless the the 5 lug was a better set up
Old 03-03-2015, 11:26 PM   #4
68shortwide
68shortwide's Avatar
Re: 5 lug or 6 lug
Gas pretty much nailed it. Other than a much wider market for wheels, really nothing. I actually like a lowered 6 lug truck, it gives it character. If my frame weren't already five lug id use 6 lug and roll with it. What's the truck look like, out of curiosity.
Jack
Personal Fleet: Family Fleet:
1955.5 Panel 1959 Apache
1968 ShortWide
1969 ShortStep
68shortwide is offline   Reply With Quote
Old 03-04-2015, 12:29 AM   #5
68bowtie
68bowtie's Avatar
Re: 5 lug or 6 lug
i agree with the others. and yeah, we need some pics. "67 all original" sounds intriguing!
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
Survivor "Lil’ Mint" (67 c10 40k mile light green original paint)
Old 03-04-2015, 12:45 AM   #6
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: 5 lug or 6 lug
Gary
+1! The pros out weigh the cons anymore...Six lug axles are a dime a dozen...Everybody wants the fives...Rally six lugs are cheaper too...No reason at all to loose the six lug axles and rotors...Plenty of reasons to keep'em though...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 03-04-2015, 08:12 AM   #7
Backnblack67
Re: 5 lug or 6 lug
I will try to post some post some pic today . It has some good patina all black . Plans for body now is to put some rockers cab corners ,leave the the paint alone and drive the fire out it . I am restoring a 67 vw bug for wife now it is in paint shop then I can get started on this one.
Old 03-05-2015, 09:22 AM   #8
volksworld
Re: 5 lug or 6 lug
back in the day of doing disc brake conversions with factory/junkyard parts,5 lug was your only option...now with aftermarket 6 lug rotors available it beats the heck out of doing an axle swap
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
Old 03-05-2015, 10:42 AM   #9
67 cst swb
67 cst swb's Avatar
Re: 5 lug or 6 lug
Gary
And Wheel/Rim choices.
If you are going to run Rallye Wheels, stay with the 6 lug.
But if you plan on running a fancy billet or chrome wheel, you may want to check to be sure that wheel is made in the 5 or 6 lug pattern you plan on running.
I agree with 68shortwide, I also like a lowered 6 lug truck, I think it gives it character.
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red
67 cst swb is offline   Reply With Quote
Old 03-05-2015, 10:48 AM   #10
Mike C
Mike C's Avatar
Re: 5 lug or 6 lug
I like 5 spoke wheels and the way they are made you need 5 lugs (each lug fits in a spoke void). I converted my '69 to 5 lug and used a 72 rear axle. On a stepside truck you are more limited in wheel width/tire size than on a fleetside truck.
To run the wheel and tire combo that I wanted/was willing to pay for I needed to go the 5 lug route. And would do that again. Once nice thing about the 5 lug is if you ever need rotors they are commonly available at any auto parts store and not a special order aftermarket item.
Price was a bout the same since the 5 lug front conversion was $100 cheaper than the 6 lug and I got a 5 lug axle off craigslist for $150 that I swapped my positraction into.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Mike C is online now   Reply With Quote
Old 03-05-2015, 10:56 AM   #11
Boog
laying low
Boog's Avatar
Re: 5 lug or 6 lug
Keep in mind stock 15" drum wheels may not clear disk brake calipers if thats what your intentions are. If yours are 16" it may be ok. Worth asking.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 03-05-2015, 11:52 AM   #12
GASoline71
GASoline71's Avatar
Re: 5 lug or 6 lug
I have deep slotted 15" mag wheels on my truck. It's a 1972 GMC with factory front disc brakes and came stock with 16" wheels. I had to do a little grinding on the calipers to get the mag wheels to fit over them.
Gary
