Old 03-03-2015, 11:05 PM   #1
scott657
scott657's Avatar
Sheet Metal repair
Ok folks , I will be attempting some rocker repair on the 63, I got 3 pieces from Classic industries. should I install them the way the catalog shows? Sandwiching "X" between "W" and "Y" ?
Thanks for the help!!
Scott
63 C10 Stepside
230 1bbl
Saginaw 3 spd
scott657 is offline   Reply With Quote
Old 03-03-2015, 11:09 PM   #2
spookylynx
spookylynx's Avatar
Re: Sheet Metal repair
brace the cab up as best you can.
cut from the outside in..
Then replace the pieces from the inside out.
Just remember to go slow, mock up before you weld, measure twice.. i mean three times...
I am new to this too, and it really wasnt that bad. just take your time
spookylynx is offline   Reply With Quote
Old 03-03-2015, 11:33 PM   #3
wilkinst
You don't need both X and W; you need either X or W, to go with Y depending on how far back you need to replace the metal. X and W really are the same part just in a different configuration depending on your situation.
Hopefully that answers more questions than it raises!
wilkinst is offline   Reply With Quote
Old 03-03-2015, 11:37 PM   #4
scott657
scott657's Avatar
I definitely need "X" for the lip, so that answers that question!!!
Scott
63 C10 Stepside
230 1bbl
Saginaw 3 spd
Old 03-04-2015, 01:31 AM   #5
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
too bad the people at the vendor are not more knowledgeable , as stated X and Y are both inner rockers, and you only need 1 if your inner rocker is shot, also if you get a floor pan, it has the inner rocker attached to it as well- so there are 3 ways you can fix an inner rocker, would have been nice if they had a prompt for the seller to ask you which you needed, of if you were doing 2 different trucks...
Old 03-04-2015, 02:01 AM   #6
Captainfab
60-66 Nut
And there is yet another option. This full length outer floor with the inner rocker.
http://www.topbananaparts.com/driver...r-section.html
This is what I prefer to use.
Old 03-04-2015, 11:57 AM   #7
63burban
Chevy addict
I would like to see how this is done with shovels and rakes ! LOL
63burban is offline   Reply With Quote
Old 03-04-2015, 03:04 PM   #8
scott657
scott657's Avatar
very carefully
Scott
63 C10 Stepside
230 1bbl
Saginaw 3 spd
Old 03-04-2015, 04:00 PM   #9
canadian_diesel1964
I think I'm going down this road as well..do you guys agree to keep as much original as you can? Even if it means more time and effort to cut here and there?
canadian_diesel1964 is offline   Reply With Quote
