Old 03-03-2015, 11:25 PM   #1
87Skier
87Skier's Avatar
Doors hit body
I know what the problem is but don't have the money or time to fix it right now, but my lack of rocker boxes, old body bushings, and rust in the floor/rockers has made my body really flexible.
So, to avoid my doors slamming into the body what are my options?
I am thinking about spacing the middle body up on the frame, and possibly adding a reinforcement bar where the rocker box should be. Would that be enough?
Also, I have the convertible shims installed (I've seen them mentioned around here before).
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 03-04-2015, 02:30 PM   #2
mtully79
mtully79's Avatar
Re: Doors hit body
No rocker boxes? That would be the priority if it were my build. Is the top on it currently?
mtully79 is offline   Reply With Quote
Old 03-04-2015, 02:34 PM   #3
dubds10
Stalker Nate
Re: Doors hit body
Close your doors and jump out like Dukes of Hazard style Cheapest way to do it until you do rocker boxes and rockers. The only option is brace that area though and keep the hard top bolted down tight, but if doing it to actually keep your doors working properly you may as well get replacement parts as it's pretty much the same thing. Once there's rust in these they flex and only way to fix it is to do it all properly unfortunately.
1957 GMC SWB stepper modified summer time driver
1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project
1965 Chevy P10 Ice Cream Truck project
Instagram - TheDonutDiner
FaceBook - @UscreamIscream
dubds10 is offline   Reply With Quote
Old 03-05-2015, 08:02 AM   #4
87Skier
87Skier's Avatar
Re: Doors hit body
Rocker boxes are at the top of my list (in a couple years), but I don't want to tear into right now and don't have the cash to do it.
For the record, I have a hard top, and when the top is bolted in place the doors shut perfectly and line up correctly. Has no one tried anything with bracing this up for a year or two?
Old 03-05-2015, 11:50 AM   #5
wannabefastcrf
Re: Doors hit body
Your options are top on, rollcage, or some big rock sliders welded in.....or maybe if you want to run without a top jsut remove the doors too
wannabefastcrf is offline   Reply With Quote
