Old 03-04-2015, 03:19 PM   #1
justin4260
justin4260's Avatar
timing adjustment
I'm going to adjust my timing. I've watched a few videos and there is a marker by the fan pulley. in the videos I've seen there is a red arrow that tells you top dead center. mine doesn't have that arrow. am i missing it or is mine different? heres what mine looks like it goes 16 12 8 4 0 4 and top says before bottom says after.
justin4260 is offline   Reply With Quote
Old 03-04-2015, 03:37 PM   #2
enaberif
Re: timing adjustment
That cut in the balancer just below that timing tab is what tells you your timing. You match that cut to a mark on the timing tab to time your vehicle.
Depending on a lot of variables that cut should be around 8-12* BEFORE when the truck is running and idling when warmed up.
enaberif is offline   Reply With Quote
Old 03-04-2015, 03:57 PM   #3
KEL
72 GMC
KEL's Avatar
what he said ! /\
In the little green circle!
KEL
Members I have met :
2014.02.01: bruceman1968, Mr Handy, colgad, RenoKeene, CaptRMW
KEL is offline   Reply With Quote
Old 03-04-2015, 04:08 PM   #4
BLT gmc
If you line the balancer notch (in the green circle) with 0 on the timing tab bolted to the timing cover, number one cylinder should be on top-dead-center(TDC). That is if all is right. The marks on the tab on the "before" side are degrees advanced and the numbers on the "after" side are retarded. Use a marker to make the notch on the balancer more visible. This will help you "see it" easier. Bruce
BLT gmc is offline   Reply With Quote
Old 03-04-2015, 04:22 PM   #5
Chucks72Longbed
Chucks72Longbed's Avatar
Don't forget, when checking/setting the timing disconnect the vacuum advance hose and plug the vacuum line to it.
72 Chevy C20 LWB-Just what I always wanted.
Now, just need more time and money!
Chucks72Longbed is offline   Reply With Quote
Old 03-04-2015, 06:05 PM   #6
justin4260
justin4260's Avatar
i don't even have a timing light lol. ill be getting one tonight after work. this is my first truck/car project.....well my first vehicle really.
Old 03-04-2015, 06:23 PM   #7
Lanman1972
Lanman1972's Avatar
Keep your Hands and Timing Light Wires out of the Fan Blades and Belts!
Lanman1972 is offline   Reply With Quote
Old 03-04-2015, 06:24 PM   #8
enaberif
Fawk did both of those last night. Clipped the front of the timing light then clipped the front of my finger.
Old 03-04-2015, 11:39 PM   #9
Raider Rudy
Raider Rudy's Avatar
Originally Posted by KEL View Post
what he said ! /\
Another suggestion is to put some paint or nail polish on the line on the balancer to make it more visible.
1969 Chevy Long Fleet Custom C/10 (2nd owner)
1971 Chevy Short Fleet Custom C/10 (2nd owner)
2001 Chevy Silverado Ext Cab
Raider Rudy is offline   Reply With Quote
