Old 03-04-2015, 07:07 PM   #1
revjames
Heater/air cond
Yes I am new to the c10 world. I have been going through threads but no found much on heater parts. Mine in my 62 doesn't do anything I haven't traced out the electric wires for power yet. This led me to ask do I even have a whole system. I know I am missing the vents but what else possibly? Pics coming as soon as I figure out how
revjames is offline   Reply With Quote
Old 03-04-2015, 07:13 PM   #2
revjames
Re: Heater/air cond
Pic 1
Old 03-04-2015, 07:14 PM   #3
revjames
Re: Heater/air cond
Pic2
Old 03-04-2015, 07:15 PM   #4
revjames
Re: Heater/air cond
Pic 3
Old 03-04-2015, 07:16 PM   #5
revjames
Re: Heater/air cond
Pic 4
Old 03-04-2015, 07:16 PM   #6
revjames
Re: Heater/air cond
Pic 6
Old 03-04-2015, 07:17 PM   #7
revjames
Re: Heater/air cond
Pic 5
Old 03-04-2015, 07:18 PM   #8
revjames
Re: Heater/air cond
Pic 7
Old 03-04-2015, 07:20 PM   #9
revjames
Re: Heater/air cond
Deluxe ??
Old 03-04-2015, 08:24 PM   #10
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Heater/air cond
I wish I knew the 62 enough to help you, but I can welcome you! Glad your here!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-04-2015, 08:53 PM   #11
revjames
Re: Heater/air cond
Thank you for the warm welcome
Old 03-04-2015, 09:37 PM   #12
par4tom
Re: Heater/air cond
Looks like a good project...my 61 has the basic heater and I wish I could be of more help...
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=705185
How to Get Audiophile Sound in 60-66 Trucks
http://67-72chevytrucks.com/vboard/s...=1#post7236896
Building Your Own Speaker Kick Pods
http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495
par4tom is offline   Reply With Quote
Old 03-04-2015, 09:55 PM   #13
davbowen
davbowen's Avatar
Re: Heater/air cond
it does appear to be a complete system. it looks like a "deluxe" heater with 4 levers. pic 1 is not part of the system, it looks like a windshield washer pump or something. pic 2, 3 shows the control valve that has been added, not part of the original. it should be inside the big black box. they tend to stop working and are not made aftermarket, maybe thats why it was added outside the box. for electrical there should be a brown wire running from the fuse block to the blower switch then from the blower switch to the resistor, pic 4, 6 then an orange wire out to the blower itself. there is a gray wire from the fuse block to the lamp in the 4 lever housing too. if the motor doesn't work, first check the fan by hooking 12v to it. these fans are available aftermarket. the blower resistor looks bad and needs to be replaced. it's not overly complicated it either the fan or more likely the resistor that is the problem. here a link for info on heaters. good luck....
http://67-72chevytrucks.com/vboard/s...d.php?t=488618
davbowen is offline   Reply With Quote
Old 03-04-2015, 09:58 PM   #14
revjames
Re: Heater/air cond
Thank you so much that is great information
