What rear end do I have
my truck is a 72 C20 402 BBC. It has 8 lugs 10 bolts holding on the rear cover. PO welded up some sort of cheesy bracket or brace for the pan hard bar bracket. I think he told me he had to put a different rear end cause he blew up the old one. Panhard bar also appears to have been cut and re-welded. Only thing I can figure is the panhard bracket that is welded to the third member is some sort of rigged up thing and the stock panhard was too long for the funky bracket. If a photo is need let me know and I'll post one. Too dark to get a pic tonite. Thanks Guys!
72 Chevy C20 LWB-Just what I always wanted. Now, just need more time and money! |
Re: What rear end do I have
Probably an Eaton H052. Comparable to a 14 bolt in strength.
71 K20 64 GMC mud truck |
Thanks 71K20. The pan hard bar is mounted to the frame (passenger side) and the funky bracket is welded on the left(drivers side) on the third member right next to the cover. It just looks wrong.
20' Daredevil (Ret)
![]() Join Date: May 2003
Pic would definitely be helpful.... based on your description I'd agree with the above, probably Eaton HO52.
Thanks Mike, I'll post a pic tomorrow.
Vintage 4x4s
Ho52 truck I parted:
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
