Old 03-05-2015, 10:41 AM   #1
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
66 AC options
Hey guys...
Buddy of mine just bought a really sharp 66 short step small window that has a AC tilt stock and a straight six / auto (Assuming 350 turbo)... The AC box that bolts to the fire wall is gone... someone just bolted a plate over it... stock center vent is present and of course no compressor etc... are there any aftermarket replacements that use the stock location... he really doesn't want to go vintage air or something similar and have to fill the location in etc...
Truck is super nice... one of the cleanest sheet metal wise I have seen... ran a magnet over the whole thing and only found one spot of bondo in the bottom of the passenger door... Anyway... looking for the options on AC really would like something stock looking but newer technology if such a thing exists...
I am way more knowledgeable about 67-72 trucks... and just purchased my first 66 a little while back... I haven't even had a chance to start on it yet...
Current Rides:
Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread
EvilK5 - 71 K5 Blazer
Evil Twin - 2006 Suzuki M109R
EvilDmax- 2018 GMC 2500 Denali Duramax
chevyguy_72 is offline   Reply With Quote
Old 03-05-2015, 11:09 AM   #2
chevyrestoguy
chevyrestoguy's Avatar
Re: 66 AC options
If he's not interested in a Vintage Air style unit, then he is going to need to find an original evaporator assembly. You can find them, but they often come with the rest of the entire system and the seller may not want to separate it. These units are big, and they hang down below the dash, but if he wants a factory look to his truck, then it's one of his only options.
The factory set-up can be modified to work with later components, but you have to make a few changes. The original units used a throttle suction valve which doesn't work that great with R134, but it can easily be swapped out for a POA valve that's calibrated for R134. These original units used barb fittings, hose clamps, and a non-barrier hose, and they aren't what you want with R134. They'll work, but there's an increased risk for system leaks. You can weld on Bead Lock insert fittings to the evaporator ends (suction and discharge) and run the crimp style fittings with the o-rings and barrier hose.
There are options for the compressor as well. If he wants to look factory under the hood, he needs to run the big A6 style compressor. If he wants to upgrade to a better (smaller) compressor and stay with a v-belt, he can go with a Sanden or a factory R4 compressor from an '80s/early '90s GM vehicle. If he wants to upgrade to a serpentine set-up, there are many factory set-ups that work great and are available at nearly any wrecking yard. Just make sure to upgrade the water pump to a reverse direction pump because it spins backwards on a factory serpentine set-up.
I'm assuming that he wants to upgrade to R134? If so, I would suggest he choose a condenser that's designed for R134. The original R12 condensers will work, but they use a tube and fin design versus the R134 parallel flow design. Usually, the R134 condensers are physically larger, but that's not always the case.
If you do your homework, you can build a great working system using factory parts from the '60s to the present.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 03-05-2015, 11:21 AM   #3
chevyguy_72
Vintage Evil
Re: 66 AC options
Thanks for the info... I really doubt he will want to go through all of that... I don't think its as much wanting to look factory and not having to weld up old holes in the firewall... thus ruining a factory AC cab...
a better idea might be to go vintage air but just cut out and bolt and silicone covers over those holes that could be removed if a future owner wanted to convert back to factory ac with minimal repair...
Thoughts on that approach?
Current Rides:
Old 03-05-2015, 12:01 PM   #4
chevyrestoguy
Re: 66 AC options
You could easily do that. You can find the factory blockoff plates from time to time, and they usually run around $40 and up for both plates. The upper plate is the thin, rectangular one and the lower plate is the square one. I have seen guys either make a new square plate or use the factory one and install the bulkhead fitting for the AC and heater lines, thereby eliminating any new holes in the firewall and still keeping the truck in a configuration that could be put back to stock in the future. The AC cabs have a few more holes in the firewall for the evaporator ports and the upper flapper door, but you could easily make a new blockoff for that and run rubber plugs for the smaller round holes.
My build threads:
Old 03-05-2015, 12:57 PM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 66 AC options
Go Vintage Air, best system out there IMO.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
