Old 03-05-2015, 11:15 AM   #1
Molberg
Molberg's Avatar
Question for 1 piece driveshaft dudes
How many of you are experiencing failure/vibration? Contacted a local reputable driveshaft builder, and he told me the length is too long for one piece. (Even with a 4" tube) said it will be fine as long as rpm doesn't exceed 3000. Lol. No good to me. Worse if I ever go with an overdrive unit. The more I read about it... Seems he's correct. At critical speed the shaft may bow and "whip" around. I did this conversion to a '72 gmc years back. Didn't notice any issues. Link below to a well known manufacturer... With a calculation table. Won't work according to this.
http://www2.dana.com/expert/wc.dll?hvtss~Decrits~
-Project Nitemare-
http://67-72chevytrucks.com/vboard/s...d.php?t=607359
Molberg is offline   Reply With Quote
Old 03-05-2015, 11:35 AM   #2
Molberg
Molberg's Avatar
Re: Question for 1 piece driveshaft dudes
The measurements I ran were for a long bed. Short bed should improve drastically.
-Project Nitemare-
Old 03-05-2015, 01:22 PM   #3
gottrucks
Many years ago, I had a '72 GMC shortwide. Originally it was a six cylinder and three speed. I drove it for a long time in that configuration with a one piece drive shaft, and then even longer with a 327 mounted in the six cylinder location with no issues ever. I eventually switched to a 350/350 in the v-8 position and went to a 2 piece at that time. I don't remember how big the original shaft was, but it was definitely big.
gottrucks is offline   Reply With Quote
Old 03-05-2015, 01:28 PM   #4
airbrushguy
My '71 C10 longbed came to me with a 250 6cyl and one piece driveshaft. Never questioned the owner about it but he bought it new and didn't seem the type to have changed it.
As before I changed to V8, it still doesn't vibrate.
Is there a chance this was a stock setup?
airbrushguy is offline   Reply With Quote
Old 03-05-2015, 02:18 PM   #5
mcbassin
Still Learning
mcbassin's Avatar
I have a one piece in my truck. My truck is a SWB with a 4.8/4L60E. My driveshaft was made at a local place and balanced. My drivetrain is smooth up to about 85MPH then I get a vibration. It feels like it's the driveshaft but I have no way to confirm it.
mcbassin is offline   Reply With Quote
Old 03-05-2015, 06:44 PM   #6
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Question for 1 piece driveshaft dudes
I had the 6.0/4l80e combo installed in my 71 LWB over a year ago. Drove it on last years Hot Rod Power Tour 3600 miles with no issue's ran 80-90 MPH sometimes. I do get a noticable sound out of it at that speed but I think it's because it's hollow. Mine was built by a drive shop locally. I don't think you will have any problems.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-05-2015, 08:09 PM   #7
gvnick
Aside from a 1 piece being arguably too long for a LWB truck, I would think you would have interference with the trailing arm crossmember. Because the pivot point is so far forward of the crossmember, I'd think you would hit the tube on the crossmember at full bottom or top out. My opinion.
69 GMC shortbed
Carbed LM4 - Manual VB TH350 - Gear Vendors OD
gvnick is offline   Reply With Quote
