Old 03-05-2015, 02:10 PM   #1
cfan10
cfan10's Avatar
Cool 96-99 5.7 vortec swap
Does anyone know what a 5.7 vortech swap consists of in a 90 suburban 5.7 TBI? Is it a direct bolt up? Trying to find a cheaper solution to 5.3 vortech. Thinking the trans will line up? Thanks in advance.
90 suburban 350 tbi
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me.
Don't mess with my truck, my momma or my money...not necessarily in that order. ©
Stand for something or fall for anything.
[LIST][*]'98 Bourbon St. Brawl ©2010
cfan10 is offline   Reply With Quote
Old 03-05-2015, 02:36 PM   #2
Slammed84
Slammed84's Avatar
Re: 96-99 5.7 vortec swap
Direct bolt up yes, direct wire up..... no way
84' C-10 Custom Deluxe
97' & 98' C-1500 Silverados
Slammed84 is offline   Reply With Quote
Old 03-05-2015, 05:39 PM   #3
kevinr1970
I don't know (never done it) but I do know there is a vortec-to-TBI manifold available from GMPP.
I would *think* that once the manifold is in place, it is a bolt in/wire up deal?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 03-05-2015, 05:44 PM   #4
kevinr1970
Manifold
But... there is this note:
"This manifold is primarily intended for use with Vortec heads on pre-1996 engine blocks. Blocks manufactured in 1995 or earlier have thermostat bypass passage from the block directly to the water pump. If manifold is used on 1996 and later engines (which do not have the bypass in the block), you must run a coolant bypass line from the manifold to the 5/8" hose nipple on the water pump (passenger’s side). Suggested routing is from the 3/8 NPSF boss on manifold to the water pump."
"These Vortec manifolds with TBI from Chevrolet Performance are designed for maximum horsepower with throttle body fuel injection and EGR usage. These manifolds will fit all Vortec-designed cylinder heads."
Might be cheaper to find a vortec 4bl manifold and use a TBI adapter?
1-11/16” bore TBI adapter
2" adapter
2-1/8" adapter
2000 Tahoe Limited
Old 03-05-2015, 07:50 PM   #5
Slammed84
Slammed84's Avatar
Originally Posted by kevinr1970 View Post
I don't know (never done it) but I do know there is a.vortec-to-TBI manifold available from GMPP.
I think he is talking about swapping the entire engine. If not, then I want the Vortec heads hes not using.....
Im sure it can be done, but there are electrical issues you will run into. One i know of for sure is the vortec motors use 4 oxygen sensors, TBI is only 2.
Also the fuel lines are different so you would want to find a donor Burban for those.
I also suggest, if you go through with it, to go ahead and make the fuel spider upgrade while the vortec motor is out.
Old 03-05-2015, 09:14 PM   #6
cfan10
cfan10's Avatar
Yeah I'm interested in changing the current 350tbi to 98 350 vortec engine, thought it'd be cheaper to do instead of a 2000+ 5.3 vortec swap. How hard is it to wire up versus a newer vortec? Thanks.
Old 03-05-2015, 09:18 PM   #7
kevinr1970
For some reason I read it that he wanted a vortec "long-block" and to keep the TBI; after rereading the OP, not sure where I got that
So yes completely different wiring, fuel delivery, etc.
The only thing I think you would save going vortec 5.7 vs. 5.3, is engine mounts, and manifolds/headers and exhaust mod.
I have seen people asking silly $ for a high-mile 5.7, and I have seen some pretty cheap LS engines, that part might be a wash.
2000 Tahoe Limited
Old 03-06-2015, 12:00 AM   #8
y5mgisi
Second Chance Program
y5mgisi's Avatar
Definitely go 5.3 over the 5.7. you will be in it the same amount of effort and money.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 03-06-2015, 12:43 AM   #9
MrSS
Vortec long block, vortec tbi intake from edelbrock or gm performance, possibly a Tbi chip if you are adding mods to it. All the accessories should bolt to the block as they should. Vortec exhaust manifold for egr. This should be a weekend type deal when you have the parts.
MrSS is offline   Reply With Quote
