Help ID front axle
Hi first time post . I have a 1955 pickup and the front axle has been replaced with a drop axle casting number 3712013gm27 is after market or real GM part the old axle has casting number of 3712013GM25. I need to be able to ID the axle for low volume certifcation for rego here in new zealand .
Re: Help ID front axle
How do you know axle is replacement drop axle?
Part number is for real axle, stock for 1955 truck. Casting number is part number. Original cost $31.75. http://www.gmpartswiki.com/getpage?pageid=67646 http://www.gmpartswiki.com/getpage?pageid=68232 http://www.gmpartswiki.com/getpage?pageid=23713 Option code in third listing is is F022. Listing is here: http://www.1955gmc.com/1955-59gmcguide.html hth |
I bought the truck with the drop axle fitted it is a replacment as I also have the orginal axle both have the same cast number but the std axle ends with 25 and the drop axle ends with 27.
FYI, GM part numbers do not contain "GMXX." The part number as shown above in the GM parts books is 3712013. It is possible that someone had a factory axle reshaped for the drop. We did that with a vintage racecar years ago.
There are a couple of guys here that have worked for GM and might shed some light on the "GM27" portion of the code. I think one has a 70's truck and might be found in one of the newer model forums. I'd love to know what that indicates. Last edited by 1project2many; 03-05-2015 at 05:38 PM. |
I may have worked out my droped axle. Found a axle guy called nostagia Sids chevy axles and he takes std axle and drops them up to 4 inchs anybody used his axles. good are bad.
The axle we had done is still in use under the vintage racer 20 years later. It survived a pretty good front end hit along the way.
