Old 03-05-2015, 10:49 PM   #1
esbstuff
Poorly 'Restored' 74 GMC
Can you name the things that are not correct?
http://www.ebay.com/itm/1974-GMC-Sie...p2056016.l4276
This should be a lesson on how not to do it...
esbstuff is offline   Reply With Quote
Old 03-05-2015, 11:05 PM   #2
dragonball98312
dragonball98312's Avatar
Re: Poorly 'Restored' 74 GMC
Head light bezels are for 79-80 and the bed is off a newer truck that has square gas doors. Only obvious ones for me
dragonball98312 is offline   Reply With Quote
Old 03-05-2015, 11:09 PM   #3
dragonball98312
The tail gate also isn't the proper 73/74 one. Hate how the white two tone stops at the tail lights. Good looking truck none the less
Old 03-05-2015, 11:09 PM   #4
E.D.75GMC
E.D.75GMC's Avatar
How they stopped the two tone at the tail lights bugs me to no end, but still it's clean.
E.D.75GMC is offline   Reply With Quote
Old 03-05-2015, 11:40 PM   #5
f.monroe
f.monroe's Avatar
Paint on center section of tailgate and bedsides missing, later model bedsides with gas tank doors, no white paint under rear window, wrong tailgate insert, 79-80 headlight buckets and lower grille/valence trim, fully blacked out grille, that looks like a a/c idle stepper motor mounted on the carb linkage, no windshield wiper motor liquid lines, and that wild fuel line are a few that stand out badly.
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 03-06-2015, 12:11 AM   #6
hatzie
Moderator
hatzie's Avatar
Buyer beware. At first glance it looks pretty clean but it's not what he is trying to sell with his ad copy.
I happen to like the fuel doors and the later headlight surrounds. Those are not a "numbers matching" feature on a 1974.
I do see some possible Bubba wiring being covered up along the firewall with gray split loom. A properly done restoration repair would include re-wrapping that in wire harness tape. No need to hide a proper repair. No telling what's underneath that loom. The wiring draped along the top of the exhaust manifold is another nice touch.
The Autozone battery cables are not correct. They should be side terminals and the ground should be Black.
Notice the custom 454 425HP decal on the air cleaner??? The 1974 454 GMC truck motor was 230hp/325ft lb...
The incorrect 2 tone that ends before the tailights and doesn't continue across the tailgate is another glaring neon sign that this rig might not meet expectations. Once I spot sloppy work like that it starts to make me very leery of what might be hiding under that new paint on the body and engine.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 03-06-2015, 09:40 AM   #7
esbstuff
Incorrect fuel gauge
wrong fender emblems
missing steering column to dash cover
incorrect paint line passenger fender
missing wood grain from the steering wheel
incorrect paint on firewall
wrong decals on air cleaner
wrong decals on core support
paint on master cylinder
no washer fluid lines from wiper motor
wire nuts on wiper motor
wrong radiator cap
under hood not painted body color
inside of fenders not painted body color
after market rear bumper
wrong drivers fuel tank
carb cable under column
unknown toggle switch under light switch
pop rivets holding the side cab molding on
Old 03-06-2015, 10:31 AM   #8
Bigstevex4
Bigstevex4's Avatar
At least they Didnt say the origonal milage was 6,000
83 c10 long Box Daily Driver
90 Jimmy parked
98 Road King/ 06 Road Glide
In memorium
63 impala SS/ 65 Chevy Panel
65 GMC Short Box/ 68 Camero
Bigstevex4 is offline   Reply With Quote
Old 03-06-2015, 11:04 AM   #9
77K10Silverado
77K10Silverado's Avatar
Grille and bumper stick out to me right away. Then the paint lines, headlight bezels and tailgate trim. Next is stereo, engine bay mess. Also should the mirrors be the bigger style that were typically with the Camper Specials?
Mike B.
77 K10 - http://67-72chevytrucks.com/vboard/s...=1#post6752641
77K10Silverado is offline   Reply With Quote
Old 03-06-2015, 01:48 PM   #10
kevinr1970
The only thing I really have a problem with is that he states "all original", when clearly it is not.
Looks decent enough otherwise.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 03-06-2015, 02:32 PM   #11
ray_mcavoy
Originally Posted by f.monroe View Post
... no white paint under rear window ...
The original 2-tone paint on Dad's 77 GMC was like that. The secondary color didn't go all the way across under the rear window. The rear cab molding covers it up to the point where it's hardly noticeable. But it stands out more on that ebay truck because the cab molding appears to be mounted down a bit lower than it was from the factory.
I think that changed for 81+ though. The narrower rear cab molding used for those years doesn't cover that area as much so they did run the secondary paint color all the way across under the window.
Maybe I'm missing something, but what's incorrect about the fuel gauge?
ray_mcavoy is offline   Reply With Quote
Old 03-07-2015, 12:02 AM   #12
Slammed84
Slammed84's Avatar
I'd pimp it, its a nice truck...... just shouldn't be advertised as "fully restored"
More like a nice restoration but not factory correct on everything.
Probably nicer than my truck will ever look
84' C-10 Custom Deluxe
97' & 98' C-1500 Silverados
Slammed84 is offline   Reply With Quote
Old 03-07-2015, 06:37 PM   #13
74CustomK20
74CustomK20's Avatar
All original? Didn't know the covered up the dashes new in 74...
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
