Old 03-05-2015, 11:18 PM   #1
jgmc
Drive shaft issues pinion angle
I have a 1972 Gmc 1500 long box. The truck has 4" drop springs and 1" blocks in the rear. I raised the carrier bearing (the hanging rubber style) to the high position on the cross member, has anyone else done this? Do people use pinion shims? What does everyone do?
jgmc is offline   Reply With Quote
Old 03-06-2015, 12:20 PM   #2
67 chevelle
67 chevelle's Avatar
Re: Drive shaft issues pinion angle
I have a 5 3 drop on my 68 long fleet . Did not change anything , not even the panard bar , I have not had an issue
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 03-06-2015, 04:02 PM   #3
Lee H
Lee H's Avatar
Get ahold of an accurate angle finder and do some checking. Many good youtube videos to learn how to check. Check the pinion and trans angles. You should shoot for 2-3% down on trans and 2-3% up on diff. Much more or less and you will see driveline vibration. Combinations of drops and aftermarket trans cross members and mounts will change the angles. Also measure the diff and see if it's centered.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 03-07-2015, 01:19 AM   #4
Z10
Z10's Avatar
A friend of mine showed me an app for my phone by Tremec which includes a drive line angle finder. It's free for iPhone. Tremec Tool Box. It measures and calculates.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
