Old 03-06-2015, 10:38 AM   #1
zicc1835
zicc1835's Avatar
Front Airbag suspension info
i have a ECE 4-6 drop kit and plan to use bags in the front , with the drop spindles from the kit when i do the conversion i will do ball joints and rebuild the upper and lower control arms from the kit. I am wondering how the difference in the hight will affect the tow in and out or caster camber . also if i should replace the same amount of shims that are present on the A arms all advice is much appreciated I have replaced drop springs before ....but will be a first for a redo on all with bags
zicc1835 is offline   Reply With Quote
Old 03-06-2015, 01:23 PM   #2
tinydb84
tinydb84's Avatar
Re: Front Airbag suspension info
You should take it for an alignment. You can use an angle finder on the disc at ride height to get you close enough to drive it to the alignment shop if you are really worried.
David
Instagram: myfabguy
Old 03-06-2015, 02:09 PM   #3
SCOTI
SCOTI's Avatar
Yep.... It will need to be re-aligned once the bags are swapped in.
The alignment is set w/the bags @ the intended ride height. If it's above or below that height, the alignment will be 'off' so changes in camber & caster will be noticed.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-06-2015, 07:11 PM   #4
zicc1835
zicc1835's Avatar
thanks
Old 03-06-2015, 07:18 PM   #5
zicc1835
zicc1835's Avatar
thats what i was wondering .....so for now i think I'm gonna use the springs that come with the kit and keep it at the 4 inch drop ....unless you can tell me the advantage of bags in the front I put them in the back with Schrader valves so if i tow i can inflate them , I'm assuming with the rear at normal ride hight no towing I'm gonna get a better ride than the coil springs ....is that true for the front also will i get a noticeable difference with the ride ?
Old 03-06-2015, 11:05 PM   #6
72MARIO
72MARIO's Avatar
Make sure you get a hard measurement from bump stop to cross member when you get the alignment done. Air pressure alone will not put the truck back to the exact same height the alignment was set at. That measurement will need to be checked.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 03-07-2015, 09:28 AM   #7
zicc1835
zicc1835's Avatar
thanks for that info ....any pictures of that bagged burb
Old 03-07-2015, 10:54 AM   #8
72MARIO
72MARIO's Avatar
Hijack..towing and road trip
2005 TAHOE DD
Old 03-07-2015, 07:45 PM   #9
NEWFISHER
NEWFISHER's Avatar
Once you install the rebuild parts and the bags, grab a framing square. With it "settled" (roll it fwd and back several feet) position the short end of the square against the flat pavement and the long end up the face of the wheel/tire. Add or subract shims until you have 1/32 inch between the top face of the tire and the square. Set your toe with 1/8 inch or slightly less and drive it. I stopped paying for alignments and have no tire wear issues on bagged vehicles. I also square the rear axle to the chassis before any front end measuring.
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 03-07-2015, 07:55 PM   #10
zicc1835
zicc1835's Avatar
real nice ride
Old 03-07-2015, 07:57 PM   #11
zicc1835
zicc1835's Avatar
wow i like it will give it a try thanks for the info
