03-06-2015, 12:49 PM | #1 |
spark plug wires
Does anyone know where I can get spark plug wires that are put together that are long enough to go around the valve covers and not over?
03-06-2015, 01:17 PM | #2 |
Re: spark plug wires
Summit, Jegs, Fig Speed, Speedway Motors. MSD, Mallory, Taylor, Accel
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
03-06-2015, 01:56 PM | #3 |
I have a stock set new in the box for a set of rams horns the came up from underneath. All the above mentioned have the cut to fit sets. A good plug wire crimper makes for a nice set.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
03-06-2015, 02:09 PM | #4 |
If you order a set for a corvette they should go under. I am not sure about the older ones because I have HEI dist and I use the corvette wires so I can go back and under.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
03-07-2015, 11:49 AM | #5 |
Sooo it appears that I have to cut them. No one makes ones precut that will go in the outside of my valve covers?
03-07-2015, 12:17 PM | #6 |
"Where were you in '62?"
MSD's Replacement Spark Plug Wires and Coil Wires are made with the same Super Conductor wire as their universal and pre-made sets, just longer than normal for custom tailoring when you need that extra length.
http://www.jegs.com/p/MSD-Ignition/M...27162/10002/-1
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
03-07-2015, 12:48 PM | #7 |
If you aren't afraid to make your own you can get a set from Auto Zone for around $15.00, add a MSD crimping tool and you're done.
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
03-07-2015, 12:59 PM | #8 |
They're easy to do, and a custom made set always looks better than a generic out of the box set.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
03-07-2015, 01:09 PM | #9 |
Make your own, you'll be so much happier, and able to route them away from heat sources better.
03-08-2015, 12:04 PM | #10 |
x2 use 75 corvette plug wires for hei, and 74 and older for point type dizzy they both work and fit perfectly.
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice |
